Mast Mounted VHF - SailNet Community
post #1 of 4 Old 02-26-2005 Thread Starter
Mast Mounted VHF
Isn''t that name cute? I thought of it all by myself here in Columbus, GA.
But soon I''ll be sailing down in the Gulf and I want to install a VHF radio with a mast mounted antenna before I get there, novice that I am. How do I run the coax on a trailer sailor like my boat? What kind of coupling would I use at the base of the mast?
JebButler is offline
post #2 of 4 Old 02-26-2005
Catalina 38 Avantura
duffer1960's Avatar
Mast Mounted VHF
I ran it down by leaning the top of the mast against the garage then going up on the roof and feeding it down from there. I used a bulkhead connector on the deck next to the base of the mast. Worked fine.
duffer1960 is offline
post #3 of 4 Old 02-27-2005
Mast Mounted VHF
How are you protecting the coax from the sharp edge of the hole at the bottom of the mast?
jbanta is offline
post #4 of 4 Old 02-28-2005
duffer1960's Avatar
Mast Mounted VHF
I installed a rubber grommet in the holes at the top and bottom of the mast.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
