Old 03-01-2005
hrmacdonald2000 is on a distinguished road
Hull / Deck Joint on Pearson 303
I was reading a Practical Sailor review on the Pearson 303. With regard to the hull/deck joint, they are of the opinion that it is fastened with self-tapping screws. They also feel this type of construction is, "perfectly satisfactory", for coastal cruising.
I am of the opinion this was a short cut by the builder and a boat of this size should have been through bolted.
Does anyone know for sure if this joint is constructed with self-tapping screws or through bolted. If it is self-tapped, should this be a concern?
Thanks, Hugh...
Old 03-01-2005
RichH's Avatar
RichH will become famous soon enough
Its held together with screws for assembly purposes and drawing the deck to the hull mechanically .... then the internal portions of the joint is filled and overlayed with fiberglass roving and resin. Dont ever break one its a bitch to repair.
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Leaking hull deck joint sailnaway Gear & Maintenance 0 10-12-2004 07:53 AM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 07:11 PM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
Columbia - rub rail/hull deck joint?? stiffel Gear & Maintenance 2 11-14-2002 01:49 PM
