low-budget performance passage-maker - Page 2 - SailNet Community
post #11 of 17 Old 03-26-2005
paulk's Avatar
A thoughtfully prepared Islander 36 would have had to have so much gear rebuilt and replaced that it might be difficult to consider it to actually be an Islander 36. It would likely be cheaper to buy a Morris 36, new, which would also give you some assurance that the thinking involved in preparing it (the Morris) was correct. Once in Europe, an Islander 36 would be fine, but based on what I''ve seen of them, the best way to get one transatlantic might be on the deck of a freighter. The North Atlantic can have big, smooth rolling swells and steady winds, like the Pacific. It can also change in less than a day to other, quite nasty conditions, with breaking 20'' waves and winds over 40 knots, and cold, besides. (Do you have a heater?) People have made it across in lots of different craft (the Brendan Voyage comes to mind) but the amount of adventure one generally wants to have is not always up to that level, especially if the traveler insists on being alive at the other end. JeffH summed it up nicely in another post on this forum about transatlantic voyages. He suggested that a transatlantic circle was probably the equivalent of about 10 years of HARD USE (my stress) to a boat. Perhaps yours would be up to it after you had thoughtfully prepared it, but it seems like a long row to hoe.
paulk is offline
post #12 of 17 Old 03-27-2005
Dave, I reach a different conclusion about the I36 than Paul does. First, both the Tahiti run and a crossing from Bermuda to the Med are relatively easy in-season passages, presuming you have some ability to gather on-board real-time weather f''cast products and understand how to use them. It''s a different story if you take a more northerly route across the Atlantic, but you would know that going in.
I36 boats sail well and were relatively simple in systems and layout by today''s standards. Your issues would be the rudder and all the ''consumables'' with finite life spans (engine, tanks, rig, steering, ports, etc.). Paul''s point that you can spend tons of money on upgrading is true...but not mandated. When I''ve had access to West Coast periodicals, it seemed to me there were always a few I36''s that had been partially refurb''d, had been used in the light SoCal airs, and would be worth looking at more closely. That being said, there are a LOT of ways a 30 year old boat can cost you money, and a basic thumbrule would be to shop caefully & keep the boat simple.
At least you can sail the I36 back from the Med or even N Europe via Biscay, Iberia, etc. In the Pacific, I think it''s time to call Dockwise...or better yet, see what boat shoppers in Oz or NZ think of her.
Jack
WHOOSH is offline
post #13 of 17 Old 03-29-2005
Thanks guys. I''ve been lurking here for a few years, and I now have the boat money (not the boat yet), and am close to a viable kitty/work arrangement, but now, of course, other things have come up to keep me on land. Anyway, while I''ll keep saving and keep planning and dreaming, when I do buy I''ll probably plan on staying basically coastal. I''ve just moved to SoCal (I knew you''ve lived here, Jack, and would know a bit about I36''s)...hmmm, there''s an I36 for sale that comes with a slip in Marina del Rey! I could do worse, I figure, than spending a couple years sailing around the Channel Islands...If I really need to cross an ocean again, I might just do it on other people''s boats (as I did my only other time)...
DaveB. is offline
post #14 of 17 Old 07-12-2005 Thread Starter
catamount's Avatar
I know when I started this thread I said I was still about three years away from buying a boat, but.... you got to open the door when opportunity knocks, right?
I''ve just bought a 1980 Peterson 34 offshore racing sloop -- While the boat does need a lot of work it also offers a lot of potential. We feel we got a great value, and my curmudgeon of a surveyor basically agreed.
I like the hullform -- it''s not extreme IOR. She sailed beautifully on our delivery up the Chesapeake to Annapolis this past Saturday. FWIW, this boat is the "customized" racing version of the Peterson 34, lightened in the ends (no v-berth, shortened cabin house, etc...) and with a large deck-level racing cockpit, with mid-cockpit traveller.
I am open to any suggestions on modifications to facilitate single- and short-handed sailing of this old IOR race-horse. I am contemplating extending the cabin house a foot or so aft to give a bit more headroom in the galley and nav station (more like the regular racer/cruiser version of the Peterson 34), re-designing the cockpit to add some coamings and seats, and moving the traveller forward a foot or two (to a new bridge deck) while moving the huge primary winches aft a couple feet (essentially swapping the winch and traveller positions), so that you can control all the sheets from the helm position (tiller steering). Then there''s the question of roller furler (or maybe hanks) vs. the foil that''s on the headstay now, and the possibility of slugs and lazy jacks for the main...
I will also be re-working most, if not all, of the interior systems, as well.
As an intersting side note, this boat''s mast was replaced about 10 years ago -- with a mast taken from a J35! (see the post that started this thread to understand why that is interesting.) With the exception of the boom length (shorter on the Peterson 34), the sailplan dimensions are within inches of each other between the two boats. The Peterson 34 is a deeper hull, though, so a short section was spliced onto the butt of the mast to make it fit.
Regards,
Tim
catamount is offline
post #15 of 17 Old 07-12-2005
Moderator
Jeff_H's Avatar
Congratulations. The Peterson 34 is a reasonably nice boat for the Chesapeake although they can be a real bear downwind and require a very large variety in the headsail inventory. They are not very tollerant of the wrong jib being a little tender and yet needing huge headsails to sail in winds at the lighter end of things.
I heavy winds you somewhat steer these boats with the mainsheet (they want to wipe out pretty easily)and so you might want to keep the traveller adjustment within reach of the helmsman for cruising purposes.
Unless you planned to keep the boat for a long time I would suggest that you make very few expensive changes. These boats have a very limited market value and so it would be hard to get much of an additional investment back out of them.
All of that said, I basically like these boats and think they are usually represent a good boat for the dollar.
Jeff_H is offline
post #16 of 17 Old 07-12-2005 Thread Starter
catamount's Avatar
Jeff, my plan is to keep the boat at my father-in-law''s dock in Annapolis for the next year, and then sail it up to New England next summer, after which I will have it trucked inland to my home in New Hampshire for it''s overhaul and refit. Hopefully I will get in enough sailing time between now and then to have a better feel for what modifications make sense.
But this boat seems to offer most of what I was looking for: windward ability, light air performance (at least relative to heavy cruisers), a good sea-going interior, offshore cability, etc... so I may well end up keeping it for quite a while.
Consistent with your comments, the boat came with a very large inventory of sails. Most of them appear to be in reasonably good condition (at least for cruising), and some -- like the Blooper -- I''m never likely to use. I think figuring out the most efficient way to effectively "change gears" with a short-handed crew (or single-handed), will be the key to successful cruising with the boat. That and avoiding fast sailing dead downwind in heavy air and seas....
I am aware of the limited market value, since that is one of the reasons I was able to get this boat as inexpensively as I did. The seller was also ready to part with his boat and apparently preferred playing golf over putting a lot of effort into making the boat more marketable (although he clearly did care for it over the many years that he owned it -- at least for those things that made it a fast racing machine). And I made a firm low offer, with the survey being a make-it or break-it thing rather than a point for further price negotiation. So I think I''ve got some value to work with here.
Regards,
Tim
post #17 of 17 Old 07-12-2005
Moderator
Jeff_H's Avatar
Hi Tim,
That all makes sense. I am not sure that this will ever make a good offshore boat. They were designed for big crews and lots of sail changes but I suppose you will sort some of that out over time. I live and sail out of Annapolis and would enjoy seeing your boat when you get her up here and would be glad to make suggestions if you would like. You can email me directly.
Good luck
Jeff_H is offline
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 12:51 PM
Reflections of an Offshore Passage Bermuda Seamanship & Navigation 4 07-23-2006 09:03 PM
Rant: Passage Maker Magazine tadmcd General Discussion (sailing related) 6 02-26-2004 12:45 PM
A GUIDE TO OFFSHORE PASSAGE MAKERS (Sailing Vessels) piclarke Crew Wanted/Available 0 05-13-2003 05:43 PM
Panama Passage TakesMeAway Crew Wanted/Available 0 06-30-2001 09:00 PM
