12-02-2005
Super Moderator
hull deflection
I basically agree with Sasha on almost all of his points. Deflections at supports are pretty common on older production boats. Whether they are a serious problem or not is highly dependent on where they occur, how deep they are and how the boat was constructed. That kind of call is best made by an experienced surveyor or repair yard. I would suggest that you discuss a limited scope of service with the surveyor. In other words, contact the surveyor and explain that you have a concern about this problem. In advance negotiate a set of fees from the surveyor that assumes that if the problem is serious you will not proceed with a full survey, and only pay him for his time and expenses to make that call, but if the problem is minor, then you will proceed.
I somewhat disagree with one minor point in Sasha''s otherwise good advice. Sasha said that deflection like this is typical on lighter performance boats. I disagree. Light weight performance boats are generally engineered to be quite stiff and so have the kinds of framing to minimize this kind of deformation. They may also bve cored which further would reduce the likelyhood of deflection. But fiberglass is very flexible as a material but loses strength over time when deformed. This kind of deformation is far more typical on volume production boats and even on pretty heavily built cruising boats that lack proper framing and/or coring than it would be on lighter performance boats were the loads aree smaller and the engineering and build quality much higher.
Respectfully,
