If you were to chose between Tartan 30 or Ranger 29 for cruising, which one would you pick and why? It is a similar S&S design. Rangers are not as common on the market as Tartans and they cost less. I'm sure there are reasons for it.
Thank you for your input.
From what I understand, Rangers are good boats and popular for racing.
I am aware that they sometimes have a keel sump problem that allows the keel to wobble. The solution, is some kind of metal grid or cross, built into the bilge area. It's not a casual task, but it doesn't make the boat worthless either.
The Tartan 30 came in two configurations, aft galley and starboard galley. If it were me, I would choose the aft galley but you loose one quarter berth, the starboard galley config has two quarterberths which makes for more storage/guests. My cousin has the starboard version with the Atomic 4 engine. The A-4 is a nice engine if maintained and has plenty of power, easy to work on but then you have the whole gas fume issue versus diesel. I do know that the Tartan sails quite nicely!
Don't know much about the Rangers.
The Ranger 29 is an encapsulated keel... ie the keel form is part of the mold and the ballast fills that cavity.. no keel bolts, so very unlikely any 'wobble'. She's a sweet sailor, the Mull Rangers, esp the cruising ones (23/26/29/33) are surprisingly slippery and sail well to their ratings. The racer cruisers (28/32/27) are more extreme IOR influenced hulls with a lot of tumblehome, bolt-on keels and more extreme rig dimensions (short E) and tend to be the typical death roll machines comparatively speaking.
Our son's 'first boat' of his own was an R29. It served him and his family well, and they did well in beer can racing. Since moved up to a C36 but still he has a 'soft spot' for #1. In the '80s my brother owned an R28.. we had fun with that boat but she was 'sailed hard and put away wet' as they say.. bit of a wild ride in a breeze.
OTOH the T30 seems to be universally well-regarded, so I'd say it comes down to which one simply 'feels' more right when you're on board.
You are right, Ranger is a Mull design but this one looks like a S&S knockoff. I think both were IOR 1/2 ton designs. R32 was designed as an IOR 3/4 tonner - looks like a very solid boat but too big for me.
Check these links and come back and confirm which Ranger is under discussion... They are different looking boats but both from Mull. Sounds to me like you're talking about an R 28.
I was looking for a ranger 29 at one point. A very sweet boat.
But the keel CAN have a wobble as the survey I ordered for the boat pointed out.
There was no apparent stress crack or anything like that but you could move the keel slightly relatively to the hull by yanking on its bottom as it was hanging on the lift.
I remember feeling (hard to access at the time) that the cross-members (or at least one) were debonded in the keel sump so that might be all there was to it.
But again, that being said it felt like a very sweet boat.
Good, that's clear.. but to me the R 29 has a greater resemblance to some Ray Hunt designs than "S&S".. No matter; once one knows of the 2 designs they are clearly quite different, as you say.
The 29 is a much better behaved sailing boat than the 28. The Tartan should be more in line with the 29, I'd think..
Ranger 29 is faster than Tartan 30 but it also has less room (Tartan is longer and beamier). Not sure about workmanship on Rangers. Tartans are usually well made.
The engine access on the T30 is truly amazing.
Quite a good sailor too.
A few flavors of T30 as well.
There is a "C" rig (C for competition - longer mast, maybe deeper keel)
and a Std rig.
You should also consider the Yankee 30, which is a close cousin to the Tartan 30. The Yankee has some nice properties compared to the Tartan:
* Chainplates go to fiberglass knees bonded to the hull instead of to wooden bulkheads
* It has huge cockpit lockers instead of interior quarterberths.
* There are vertical drawers alongside the hanging locker, which I think makes a little better use of the same space.
A downside is that the Yankee 30 is a little less beamy, and thus has a little less interior room. It also has less freeboard and windage, so it might be a hair faster.
Both are well built boats and have more in common than to differentiate them (including the great central motor location).
I looked at one Tartan 30 that had the galley to starboard. I think I would much prefer an aft galley. I enjoyed sailing it, very responsive but the boat just did not turn me on. I don't know if it was that cork floor, or just the general condition of the boat. It did not seem to have nearly the fit and finish of the bigger Tartans I have seen, but again it may just have been the condition of the one I looked at. They were asking way to much too, and ended up selling for less than half what they started asking. I think I would have offended them if I told them what I thought it was worth!
Given you previous minimalist sailing, and your desirer for efficient sailing in thin waters I recommend you check out the Tartan 27. If looking for faster, well built and even more offshore able I would choose the Tartan 34 C. Both are shallower draft and in similar price ranges to the Tartan 30 and Ranger 29. Just suggestions for a lot more anchorage choices in thin waters.
Thanks for the suggestion. I agree, those are good boats for my area. T34C is probably on the upper range of boat size I'm considering. There was a time I was seriously thinking about a centerboarder in that range. I think I liked the Corvette 31 the most. But there is something to be said for simplicity of a solid keel. It is all a game of various compromises when it comes to boats.
Related Threads
1.7M posts
173.8K members
Since 1990
