Standard diesel for Bristol 29.9? - Page 2 - SailNet Community
post #11 of 20 Old 03-05-2014 Thread Starter
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Standard diesel for Bristol 29.9?
Thanks, guys!
I didn't know that the A4 came in different hp ratings; everyone just says "Atomic 4" never "12hp Atomic 4". Then again my hearing is shot...
There were no pics of the engine in the listing, not a good sign.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #12 of 20 Old 03-05-2014
Barquito
Barquito's Avatar
The A4 is just the A4. I think he was talking about the diesel replacements for the A4.
Valiant 32
Barquito is offline
post #13 of 20 Old 03-05-2014
Old enough to know better
Originally Posted by CarbonSink62 View Post
I'm looking at a Bristol 29.9 this Friday. The ad says it has a Yanmar YB12 single cylinder 10hp engine. The age is the same as the boat, so it must be original.
The Boat US review says these boats were made with an Atomic 4 at first, then a 15hp Yanmar, then a 16hp Universal.
Is it likely that the owner and broker are wrong?
I'll know in a few days, but I'm just curious if anyone can confirm the stock diesel in a 1977 B29.9 (I think it is the 2QM15, but I might be confused with another boat). I can't find a reference for a Yanmar YB12, only a YSM-8 & a YSM-12.
PS she does look like a nice boat!
It looks like a decent boat at a good price:
1977 Bristol 29.9 Sail Boat For Sale - www.yachtworld.com
...but a 10hp engine (even a diesel) isn't gonna move it very quickly.
Ken
Yes, diesel do put out more horse power at lower RPMs.
Thanks, guys!
Well the A4 is "rated at 30 HP" but you have to rev it very high to get that. Most people seem to have them propped to have much lower RPM as the motor is happier at that range. Gas engines seem much happier at lower power output. The diesels need to have a "load" on them and are happiest at the max HP output so people prop them to be at the peak HP as that is max efficiency. So it is not an apples to apples comparison.
miatapaul is offline
post #14 of 20 Old 04-27-2014
So what did you think of that boat? How many horsepower did it actually have?
Pocasset Sailor is offline
post #15 of 20 Old 04-30-2014
JimsCAL's Avatar
I may be a little late to this party of be of help, but here's two comments.
My previous boat was a Cal 9.2 (30 foot) and the 11hp Universal 5411 pushed it just fine.
The issue with the Atomic 4 is that most are direct drive (no reduction in forward). This means a small fine pitched inefficient prop and the engine is never loaded up to anything close to the rated 30 hp. A 10 or 15 hp diesel with a 2/1 or higher reduction gear and larger prop will produce more thrust than the A4.
JimsCAL is offline
post #16 of 20 Old 04-30-2014 Thread Starter
Load Bearing Member
Dock
I can't find the picture I took, but it was a very small diesel; not the QM15 (which I had seen pics of before).
As much as I wanted to like it, the boat was just 'ok'.
The deck had been painted and was peeling everywhere.
The price to replace the original underpowered diesel was US$7,500 (15hp) or $9,800 (21hp) for just the engine. Add to that haul, store, install labor, and launch ($3k? $4k?); there was no way that it was happening.
I found another B29.9 in Tiverton, RI that we both like better; we close this Friday.
Zen Again
post #17 of 20 Old 05-26-2014
I have a 1978 29.9 #94 with a standard Yanmar 2QM15 raw water cooled. Pushes the boat to hull speed easily with some available "emergency power" using a three blade prop. As I understand it Bristol would equip the boat with what was available that the purchaser wanted at the time.
NewAdventure is offline
post #18 of 20 Old 05-26-2014
I have the original 2QM15 in my 1980 Hunter 30 and it's still going strong. Grranted the boat spent its first 20 years in fresh water (great lakes). Aside from normal maintenance, I have repaired the fuel pump and replaced the mixing elbow.
jfurlong is offline
post #19 of 20 Old 06-01-2014
Hopefully you've found the boat for you in Tiverton; the B 29.9 is a great boat and FWIW mine is an early 1979 and has a QM 20 which I assume was an original upgrade, RWC and seemingly in fine shape after a brief 35 years. I replaced the cracked exhaust mixer last year but otherwise the engine, other than being just a bit cranky to start in cool weather, is, uh, "Bristol". Good luck to you with your purchase.
John
vermontosea is offline
post #20 of 20 Old 06-23-2014
I may be late to the conversation, but for what it's worth: We're on our second season with a 1979 B 29.9 and we are thoroughly happy with the boat. We sail in Casco Bay in Maine. 'Velella' has the original Yanmar 2QM15, that you mentioned. This seems to be a good size for the boat. We easily motor at 5 knots, at about 2000 rpms.
But I don't think that 20hp would be too much in this boat. Based on that, and in light of the fact that Bristol later included a 20hp model, 10hp might feel 'light', especially if you will be sailing in areas with strong tides or currents.
I suggest test-steaming the boat under power to make sure that you will be comfortable poking along for hours in nasty conditions.
mbmaine is offline
Rudder needed for Bristol 29/Bristol 30 JimHawkins Bristol 0 12-13-2013 01:54 PM
Diesel fuel lines -Universal 3cyl diesel argofred Diesel 8 04-18-2011 03:39 PM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
