First boat advice - Mpls to Great Lakes - Page 2 - SailNet Community
 13Likes
post #11 of 50 Old 06-02-2014 Thread Starter
Re: First boat advice - Mpls to Great Lakes
Originally Posted by kwaltersmi View Post
In good condition, the Cat/O'day/Hunter would all serve your needs. I recommend making sure whatever you get has a very reliable outboard so that you can choose conservative (read low wind) weather windows where you may end up doing some motoring. That way you'll maximize your chances of avoiding conditions that may be too much for the boats or your skill level.
Bare in mind that there's a lot of open water between Gladstone and Mac Island with few spots to run for cover if the weather/water turns snotty. However, northern Lake Michigan is an amazing cruising area. The run from Fayette to Beaver Island, then Beaver to St. Helena, then to Mackinac is spectacular, but this would mean many hours on the open water, so prepare/plan accordingly.
Gladstone to Fayette will be my first trip on Lake Michigan. I feel like that is pretty reasonable. We'll see how that goes then take it from there but yes, Gladstone to Mackinac Island is the eventual goal.
Question - when people talk about the "weather window" how much time are we realistically talking? I've heard that the weather service on Lake Michigan can be unreliable and it's a rare day that there isn't at least a slight chance of storms in the area. Do you rely on the weather service or are you just keeping your eyes on the sky? If the latter, when you decide to run for cover? At the first sight of storms or something else?
Thanks for posting.
jBlaze3000 is offline
post #12 of 50 Old 06-02-2014
Minnesail's Avatar
Originally Posted by jBlaze3000 View Post
Do many of those low 20's sized boats sail out of Duluth to the Apostles? Looks like it's about 50 miles or so...
Yeah, people do that. I hope to. There are places to duck out on the south shore, I'm not sure how it is on Lake Michigan.
Also I looked at those ads again, I think the Hunter for sale is a 23, not a 23.5. I know someone with a 23.5 in Duluth. It has a tank you flood with 1000 lbs of water ballast, so once you drain the tank it's very light for trailering, but it's a bit tender for sailing. The ad you linked to has the fixed wing keel, so it's probably less tender than the 23.5, but a bit harder to trailer.
Catalina 22
on a starboard tack
Minnesail is online now
The Following User Says Thank You to Minnesail For This Useful Post:
jBlaze3000 (06-02-2014)
post #13 of 50 Old 06-02-2014
In a past life I spent some time sailing Door county, Fayette etc in a 22' starwind (same hull as a Chrysler 22). Any of the boats on your list would do that fine. You can always launch at St. Ignace for a short hop to Mackinac. Of the boats on your list, the O'day would be my choice if in good shape. It's a shoal keel with a centerboard (rather than a swing keel) so less worry in the event of a knockdown. I have sailed on a friends ODay 23 and it sails pretty well. You might also look at an O'day 25 for a bit more room (which is also a kcb boat and commonly sold with a trailer (8 ft beam). I think they displace ~4k lbs, and could be trailered by a 1/2t suburban if equipped with torsion bars for the trailer etc.
Evetz is offline
post #14 of 50 Old 06-02-2014
TQA
Bombay Explorer 44
TQA's Avatar
I sailed/cruised a Cat 22 swing keel for a couple of years including a trip from Troon to Stornaway and back on the West coast of Scotland. I had some fairly rough seas to contend with and never felt the that the swing keel was an issue. So don't let people who have never sailed one put you off.
Fitting 4 people in overnight is another question though. Doable but cramped. See if you can find one with a pop top if overnighting is to be a regular event.
TQA is offline
The Following 2 Users Say Thank You to TQA For This Useful Post:
jBlaze3000 (06-02-2014), Minnesail (06-02-2014)
post #15 of 50 Old 06-02-2014 Thread Starter
Wow, you are right. For some reason I had it in my head that this had both a wing keel and a water ballast. I had pretty much decided to avoid the 23.5 with plans to sail Lake Michigan. The Hunter 23 looks like a whole different animal. I can actually find info on these being sailed in the Great Lakes.
I may have to take another look at this one. Good catch!
post #16 of 50 Old 06-02-2014
Broad Reachin'
kwaltersmi's Avatar
True enough, the NOAA radio forecast almost always states a chance of showers and thunderstorms. I'm less worried about thunderstorms and squalls then I am about heavy seas. You can reef, drop sail, forereach, run, etc. in temporary high winds, but sustained winds make the seas build. The sometimes short and steep waves of the Great Lakes can put a beating on you.
"Weather windows" can last for several days at a time, in which case you'll likely need your motor as often as you'll need your sails on northern Lake Michigan. Sustained high wind events seem to typically last 1-3 days and can take only a few hours to make the waves uncomfortable for a small boat.
I pay most attention to sustained wind patterns and predicted wave heights. I use a combination of intuition, NOAA weather radio, buoy data, and services like SailFlow to determine what the weather is going to do.
You'll start to pick up on normal patterns, such as the typical pattern in my homeport on L. MI of offshore winds in the morning/evenings, slack wind midday, and often moderate onshore afternoon breezes. Sometimes when we're cruising we are able to take adventure of early morning sailing, etc.
Catalina 34
kwaltersmi is online now
The Following User Says Thank You to kwaltersmi For This Useful Post:
post #17 of 50 Old 06-02-2014 Thread Starter
Well, I had my search narrowed down to the O'Day 23 and Cat 22 (until Minnesail enlightened me on the Hunter 23).
What I've realized is "being able" to trailer a sailboat and "wanting to" are two different things. For this reason I will probably avoid the 25 footers. For me its a question of "Do I want a roomier O'Day or the easier to trailer Cat"?
Again, I'll be doing one trip per year to Lake Michigan. That means trailering across Wisconsin on Highways where the avg speed is probably 80. Obviously I won't be going that fast with a boat, a wife, and 3 kids in the Suburban, but I want to be safe and not kill my vehicle either. The good part of that drive is that it is very flat. The other thing is the fact that I don't have a slip in MN yet, so I may need to trailer to the local lakes as well.
Right now I'm thinking that if I can get a slip on a lake here then I will try for an O'Day 23. If not then I'll look for a Catalina 22.
post #18 of 50 Old 06-03-2014 Thread Starter
Just looked up Troon and Stornaway on a map. Wow, that is quite a sail in a Cat 22. How long did it take?
post #19 of 50 Old 06-03-2014
Minnesail's Avatar
Impressive! Did you ever sail the 22 over night, or did you pull in some place every day?
Catalina 22
on a starboard tack
post #20 of 50 Old 06-03-2014
My first mono was an Oday 22 and I found it to be a well constructed boat that held up well with what little maintenance was done to it. It was a 1982 and I bought it in 2005. Make sure and get an outboard with electric start/ alternator. You won't get much amperage out of the alternator but something is better than nothing.
I will second the recommendation to look at an Oday 25. For the difference in displacement you're only talking about 600lbs more to tow, which is next to nothing for the added features and comfort. They still have the center board so towing will be just as easy as the 23. That and it can sleep 5, which I think would be an important feature. Also the head is fulley enclosed and not open to the Vberth with trust me was an issue with the 22 I had and it looks to be the same with the 23. It's nice to have a little door/ wall to keep the smells away, and for privacy. Also I know that an inboard engine/ saildrive engine was an option. This is a fantastic feature. As while motoring with an outboard you get the noise, vibration, and smell. If running down wind on a light day for 8 hours you'll get very tired of the outboard smell and 2 stroke fumes. Plus having tried to use an outboard in 3-4ft seas you'll soon find out they are about worthless. They will either be dunking under or popping out of the waves and revving. The inboard puts the prop well below the water where it isn't affected by wave motion. Also 5'6" standing room sounds pretty good too. That and having comfortable seatind down below with the decks being a little be higher. I think if you bring all the kids and wife and step on a 23 oday then on a 25 you'll go for the 25 every time. But your mileage may vary as they say.
In my 22 I experienced the lack of comfort below that comes from having no place to sit with a back rest. The decks were too low for me at 6'2" to sit on the settee and rest my back against the hull as was intended. The outboard came out of the water in big waves and was loud and noisy. You smelled the head all the time when sleeping in the vberth. ect ect. Good luck and happy hunting do let us know what you decide and as always pictures or it didn't happen!
appick is offline
Advice on choosing a Daysailer for the Great Lakes White Beard Boat Review and Purchase Forum 15 03-03-2013 03:12 PM
Mirage 30 (29?) or Great Lakes boat flyingwelshman Boat Review and Purchase Forum 8 09-16-2011 10:41 PM
Advice on draft from Great Lakes Sailors Grand River Raider Cruising & Liveaboard Forum 6 08-30-2011 11:23 PM
Great Lakes liveaboard help/suggestions/advice... ksmith Living Aboard 8 02-18-2009 09:25 PM
Want to start great lakes charter co. - advice appreciated!! mjpolifka Chartering 4 10-06-2006 10:47 AM
