Lagoon 410 - SailNet Community
post #1 of 3 Old 06-24-2001 Thread Starter
Lagoon 410
My husband and I are considering the purchase of a Lagoon 410 to be used immediately for coastal cruising and later for off-shore. Any comments on construction, sea keeping abilities and performance would be appreciated.
Suni is offline
post #2 of 3 Old 06-25-2001
Lagoon 410
Hi, Suni...
We''ve cruised in company, off & on, with a Lagoon 41 on our passage down to Trinidad, so here are a couple of comments we''ve heard from her owners you might want to consider...
1. If you''ve seen the boat, you know one of her most obvious virtues; the layout is comfy, spacious and workable, for living aboard or going offshore.
2. Like other cats, she''s weight limited. On the first attempt (which had to be abandoned), the owners found they couldn''t carry near the stores & ''stuff'' they''d put aboard and had to return to Florida to offload. This is especially true if you trick out the boat like they had (gen set, 2 AC units, etc.).
3. They found wave slap (bridge deck clearance isn''t what it could be) and the inability to go to weather inherent limitations in the boat''s performance, and adapted to this by being more selective about weather for their passages.
4. I helped the skipper sort out some wiring problems and wondered if the light construction provides the structural integrity for long-term offshore work (re: your comment to eventually use the boat for cruising). I''d seek knowledgeable advice on this aspect of any cat you look seriously at.
5. An elaborate metal framework bimini over the entire cockpit was the single most valued addition to the boat - provided integral davits, engine hoist, lots of shade and made handling the main far eaiser.
Also note the comments about a Dufour 47 in this section; there were some valuable insights there when you consider how much work they''re willing to take on to make an already-large cat more suitable to cruising.
Good luck on the ''hunt''!
Jack
jack_patricia is offline
post #3 of 3 Old 06-25-2001 Thread Starter
Lagoon 410
Jack and Patricia:
Thank you for your reply re: the Lagoon 410. Your comments were helpful and have alerted us to some issues that will need to be addressed.
Suni is offline
Lagoon 470 Pinote Boat Review and Purchase Forum 2 09-17-2016 06:40 PM
Folding or feathering props on Lagoon 410 Mama_Cocha General Discussion (sailing related) 1 08-08-2012 04:58 AM
Lagoon 37 DDs dream Cruising & Liveaboard Forum 0 08-03-2003 04:04 PM
Lagoon 37 DDs dream Gear & Maintenance 0 08-03-2003 04:03 PM
polars fo Lagoon 410 Mama_Cocha General Discussion (sailing related) 0 01-24-2002 04:55 AM
