Little Harbor 38 - Page 2 - SailNet Community
post #11 of 12 Old 04-19-2007
ASA and PSIA Instructor
Dingy issue/solution
Originally Posted by DavisGuthrie
Hi there!
.....re the dinghy issue/solutions. Lugging up a dinghy each evening is not high on our list; and creating a davits system on the stern is worrisome.... Davis
You might explain what your dingy issue is...we have a 12' RIB we tie of the stern, and tow behind when coastal crusing, works fine. If sailing offshore, you can put a hard dingy upside down on the foredeck, go with a smaller inflatable that you pack away, or hang whatever you want off davits - just a set of tradeoffs as to you preferences and need. One of these not a fit for yours?
sailingfool is offline
post #12 of 12 Old 08-27-2007
Davits for LH38
Hi I have a LH38 as well. No Davits. I either deflate the dinghy or stow it on the foredeck when sailing any distance. I won't put davits because i don't want to ruin the beauty of the boat. Im sure that if you intall the davits correctly you won't have any issues. The boat is solid as a rock and if they are putting davits on beneteau's and Hunters I'm sure you wouldn't have a problem. What Hull # do you have?? If you recently purchased it, it's probably one that I looked at before purchasing mine.
LH38 is offline
