Morgan 41 OI stability - Page 4 - SailNet Community
Blogs
  #31 (permalink)
Old 08-17-2009
Bellita is on a distinguished road
I singlehanded an OI 41 from Tampa to PR some years back. I had 12 foot seas approaching the Turks and Caicos when I lost the hydralic steering and the boat went beam to the seas. it's the one and only time in my life I actually saw a book fly off the port bookcase and land on the starboard bookcase. I looked like a maniac down below getting the emergency tiller on the boat and it back into a better direction, but the boat never gave me the feeling it was going over. I also had 16 foot seas between the DR and Puerto Rico for two days. I felt very secure in the boat and had a lot of confidence in it's abilities. I sure wish I still had that boat. they aren't the prettiest - it didn't point worth crap and I did have to motorsail if close hauled, but off the wind it was a beautiful sail. the boat had a ton of living area, sailed well and kept me safe and dry. I'd buy one again in a heartbeat. my two cents.
  #32 (permalink)
Old 12-26-2010
souljour2000 is on a distinguished road
Great thread...to be continued I hope..man I love takin 'a walk through the archives some days...
  #33 (permalink)
Old 01-03-2011
sailordave is on a distinguished road
I think reading the first couple of chapters of the latest (6th ed) edition of HEAVY WEATHER SAILING would give some valuable insight to the question the OP poses.
  #34 (permalink)
Old 01-03-2011
CaptainForce's Avatar
I enjoyed reading this revived 10 year old post. Back when it started I had been livingaboard and cruising Morgan OI's for 28 years. Now it's been 38 years. NO! I don't have any exagerated claims about the Out Islands, and please don't say Out "Islanders",- no such boat! No, I'm not worried about "turning turtle",- give me one account!....nada! No, I'm not worried about oil canning fiberglass fatigue , - give me one account!....nada! What is this useless speculation about? The Morgan Out Island does what it does with the same compromise as any other vessel. Is it dangerous to have one? No Is it a racing performance boat? No Is it the prettiest design afloat? No Could you keep it when tempted with a beautiful more expensive Cinderella boat? No Do I expect to find something better for the price? No After living aboard and cruising Morgan Out Islands for 39 years, will I be shopping for another boat? No Does this post provide any useful advice other than identifying there are many different expectations in owning a sailboat? No Take care and joy, Aythya crew
  #35 (permalink)
Old 01-04-2011
The stability and motion comfort of many Morgans and most of the CCA and early IOR boats surpasses that of most of almost all the newer beamy long waterline waterline and plumb bow boats....sailcalcpro is fun to check and I have been using it to get a look at alot of boats I don't know about.
  #36 (permalink)
Old 01-04-2011
Jeff_H's Avatar
Super Moderator
I must say that this is a comment that clearly shows that you do not understand yacht design and have not spent much time sailing on Morgans OI's, CCA boats, early IOR boats or modern boats for that matter. Spend some time doing some research and sail the living daylights out of these various types and your opinion will likely change and you will be in a better position to provide a vaguely useful, accurate, and informed commentary.
And while Carl's Sail Calculator is fun to look at, I would be caution anyone looking at this site to be very careful about relying on it. Because individuals post the data, over timne this site has accummulated a lot of inaccurate data on there posted both in error and/or for some specific purpose of the poster, And of course, the surrogate formulas like the Capsize Screen Formula and the Motion Comfort Index that are copied there can be dangerously misleading.
As hs been pointed out many times in the past, and as supported by respected yacht designers in past discussions, the Capsize Screen Formula and the Motion Comfort Index are surrogate formulas which tell almost nothing about the reality of a boat's likelihood of capsize or its motion comfort. In fact they provide so little indication of a boat's behavior that to rely on them in any way borders on recklessness.
Both of these formulas were developed at a time when boats were a lot more similar to each other than they are today. These formulas have limited utility in comparing boats other than those which are very similar in weight and buoyancy distribution to each other. Neither formula contains almost any of the real factors that control motion comfort, the likelihood of capsize, or seaworthiness. Neither formula contains such factors as the vertical center of gravity or buoyancy, neither contains weight or buoyancy distribution (of the hull both below and above the waterline), the extent to which the beam of the boat is carried fore and aft, and neither contains any data on dampening, all of which really are the major factors that control motion comfort or the likelihood of capsize.
I typically give this example to explain just how useless and dangerously misleading these formulas can be. If we had two boats that were virtually identical except that one had a 500 pound weight at the top of the mast. (Yes, I know that no one would install a 500 lb weight at the top of the mast.) The boat with the weight up its mast would appear to be less prone to capsize under the capsize screen formula, and would appear to be more comfortable under the Motion Comfort ratio. Nothing would be further than the truth.
And while this example would clearly appear to be so extreme as to be worthy of dismissal, in reality, if you had two boats, one with a very heavy interior, shoal draft, its beam carried towards the ends of the boat near the deck line, a heavy deck and cabin, perhaps with traditional teak decks and bulwarks, a very heavy rig, heavy deck hardware, a hard bottomed dingy stored on its cabin top, and the resultant comparatively small ballast ratio made up of low density ballast. And if we compare that to a boat that is lighter overall, but it has a deep draft keel, with a higher ballast ratio, the bulk of the ballast carried in a bulb, its maximum beam carried to a single point in the deck so that there was less deck area near the maximum beam, a lighter weight hull, deck and interior as well as a lighter, but taller rig, it would be easy to see that the second boat would potentially have less of a likelihood of being capsized, and it is likely that the second boat would roll and pitch through a smaller angle, and would probably have better dampening and so roll and pitch at a similar rate to the heavier boat, in other words offer a better motion comfort....And yet, under the Capsize Screen Formula and the Motion Comfort Index it would appear that the first boat would be less prone to capsize and have a better motion when obviously this would not be the case.
There are some better indicators of a vessel’s likelihood of capsize. The EU developed their own stability index called STIX, a series of formulas which considered a wide range of factors and provides a reasonable sense of how a boat might perform in extreme conditions. Unfortunately meaningful results require a lot more information than most folks have access to for any specific design. The Offshore Committee of US Sailing developed the following simplified formula for estimating the Angle of Vanishing Stability (Sometimes referred to as the ‘AVS’, ‘limit of positive stability’, ‘LPS’, or ‘Latent Stability Angle’ ):
Screening Stability Value ( SSV ) = ( Beam 2 ) / ( BR * HD * DV 1/3 )
Where;
BR: Ballast Ratio ( Keel Weight / Total Weight )
HD: Hull Draft
DV: The Displacement Volume in cubic meters. DV is entered as pounds of displacement on the webpage and converted to cubic meters by the formula:
Displacement Volume in Cubic Meters = ( Weight in Pounds / 64 )*0.0283168
The Beam and lace w:st="on">Hulllace> Draft in this formula are in meters. These values are entered in feet on the webpage and are converted to meters before SSV calculation.
Angle of Vanishing Stability approximately equals 110 + ( 400 / (SSV-10) )
There is a convenient calculator at Formulas
It should be noted that the AVS is only one indicator in evaluating the likelihood of capsize, meaning it only predicts the point at which the vessel wants to turn turtle. It does not predict the amount of force that would be required to heel the vessel to that limit, nor does it predict the amount of force required to right it once past the point of no return, nor does it predict how the shape of the boat might encourage wave action to roll the boat closer to the angle at which it no longer wants to return.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 09:10 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 05:09 PM
1994 Morgan 45 CC FOR SALE k5esx Boat Review and Purchase Forum 0 11-27-2003 11:31 AM
Morgan Out Island Need feedback Yflyer555 Cruising & Liveaboard Forum 4 06-20-2001 01:34 AM
Self-righting PaulSellars General Discussion (sailing related) 2 03-24-2001 02:04 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
