Crazing/Cracks on an 87 O'day 272 - SailNet Community
Blogs
Old 06-13-2006
simple72 is on a distinguished road
Hi,
I saw a nice clean O'day 272 today. The boat is well priced and in good shape overall. However, it has some crazing and light cracks around the mast step. I couldn't feel any softness but....Should I even consider this boat?
R
Old 06-13-2006
pigslo's Avatar
pigslo is on a distinguished road
always survey
Assuming you will not buy without a survey. Surveyor will sound out the deck with his little brass hammer and tell you if the deck is sound. is the mast deck stepped? If so check the compression post. Is the mast keel stepped? If so then check the mast step to see if it is allowing the mast to move and move the deck with it.
Old 06-13-2006
Agree that you need a competent survey for peace of mind (and to get insurance), but you can do your own prescreening with a small plastic hammer or even a small screwdriver handle.
Tapping around the suspect area you should hear a sharp, solid "Thunk" if the deck is sound. A delaminated or softened area will show up as a definite hollow "thud". Once you find an example it's easy to tell the difference. Another place you can often find some delam is around the cabintop halyard winches (due to the stress of hoisting sails and the torsional forces from the cranking of the handle). This is especially true if the winches were installed after the fact by an owner moving them off the mast.
Back to your mast step, if the crazing is not deep, there is no apparent deflection of the area of the mast step (assuming deck stepped), and it sounds out OK then it's worth persuing and getting a more professional assessment. This is a high stress area and gelcoat crazing is not unusual in older boats. If it sounds out like there's nothing but "porridge" between deck skins, walk away....
Old 06-13-2006
Another place that the deck commonly delaminates is around the chainplates. I would recommend checking the area around the chainplates fairly thouroughly.
Also, if the mast is deck-stepped, then look in the cabin, and check to see if the cabin roof is sagging or not. If it is, regardless of whether there is a compression post, you will need some work. In some cases, the compression post isn't properly aligned with the mast foot, so the mast foot transfers loads to the cabin roof and causes a sag.
O''Day 322 bailey Boat Review and Purchase Forum 2 09-16-2011 12:40 PM
ODAY SUPERSWIFT FJW Gear & Maintenance 8 09-30-2009 02:17 PM
ODay 34 port list Shekinah Gear & Maintenance 2 04-23-2001 02:01 PM
Pre86 O''Day vs Post 86 O''day JPC Boat Review and Purchase Forum 5 12-02-2000 10:33 AM
O''day 272 cabinmonkey Boat Review and Purchase Forum 0 11-08-2000 07:45 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
