Trailer boats - SailNet Community
post #1 of 8 Old 08-25-2001 Thread Starter
Trailer boats
My wife and I are looking to start sailing.
I am 34 and have not sailed in 13 years. When I was in the Coast Guard I crewed on a couple of sailboats in club races. I intend to take lessons. We live 125 miles from the the Chesapeake bay and the great lakes are 150 away. We own a HD pickup and are used to towing large trailers. So we feel a trailer boat is our best bet. Which are the largest trailerable boats and which ones sail the best. We would like to be able to spend up to 7 days on board mostly within coastal waters but would not mind running offshore when the weather is right.
jkelch is offline
post #2 of 8 Old 08-25-2001
Trailer boats
Trailer sailor.com is a good resource for checking out trailable sailboats. In my own search the biggest boat I''ve seen is a clipper marine 32 foot. From what I''ve read its underpowered but I''ve never sailed one. I''ve got a 22 foot O''day which is a great overnighter but probably too small for your needs. Good luck in your search.
augiedoc is offline
post #3 of 8 Old 08-27-2001
Trailer boats
Just a thought...check out www.macgregor26.com It may be the answer
Artwenk is offline
post #4 of 8 Old 08-29-2001
Trailer boats
Check out the Laguna 22 at trailorsailor.com.
cbrennan is offline
post #5 of 8 Old 07-30-2008
nobletc
Cm23
I have a 1976 23 ft Clipper Marine, that I have had since the early 80's. She is a bilge keeler (2 fixed keels) with a 6 HP Evenrude. She handles the bay winds very well and she is one of the best shallow water boats I have ever sailed.. Sailing in the south San Francisco bay, the depth can change dramatically and quickly. She has a 7 foot beam so she is comfortable and she as a pop top so you can stand inside when you are moored. She is easily trailerable and relatively easy to launch and recover. We have used her for many years without any significant issues and have enjoyed many pleasant trips up the San Francisco Delta in her.
nobletc is offline
post #6 of 8 Old 07-30-2008
mikehoyt's Avatar
Try the Andrews 28. It is trailerable but still sails very well.
"Sylvana Yachts" introduces new yachts design: ANDREWS 28
Mike
mikehoyt is offline
post #7 of 8 Old 07-30-2008
eMKay's Avatar
Holy ****, this thread is 7 years old.
Technician, RCR Yachts Buffalo.
eMKay is offline
post #8 of 8 Old 07-30-2008
timebandit's Avatar
Ok, I'll jump in here.
Towing is the easy part.
First let me say that all trailer boat are not trailer launchable (?). Some very nice fixed keel boats in the 25 to 29 foot area have trailers and can be towed but must be removed and launched with slings.
Second are the ones that use a tounge extension to get them deep enuff to launch. The problem with these is that sometimes the trailer runs off the end of the ramp before the boat launches. If that does not bother you than think of how you are going to the the boat and trailer back up over that lip. Don't forget about the other problems that arise from trying to put a boat on the trailer in 5 feet of water.
I have a Macgregor 25. Not bad but has a lot of drawbacks. Mainly no storage, it's taken up by a lot of foam. It will however launch in 2 feet of water meaning that I can launch it anywhere a ski boat can. It has a 700 pound swing keel that I have to lug around all the time when trailering.
My favorite would be one of the macGregor 26 classics wich are the 26d(dagger board) or the 26s(swing keel).
Both of the classics are water ballested so you dont have to carry about 1200 pounds around with you. You just have to open a valve and let the water flow in and you can blow it out before you put it back on the trailer. The best part is you can get into some lakes that just have a road leading down to them. The floation was moved to non storage areas and they have a queen sized berth under the cockpit. A pop top gets you some head room when at anchor.
A 10 hp outboard will get you to hull speed at 1/2 throttle.
They are easy to rigg--just undo the forestay all the rest stay connected so if you want to see what is on the other side of that bridge--go for it. Want to beach it on that sandy beach--pull up that under carrage and kick up the rudder and go for it.
If you want you can slip in a marina for the season and then put it in you driveway in the off season for maintence for free.
Rick
timebandit is offline
First time sail boat buyer martinojon Boat Review and Purchase Forum 20 05-26-2014 09:16 PM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
Cruising Boats KPBaker Boat Review and Purchase Forum 12 12-01-2012 06:35 PM
IOR...CCA... help! sherbet Boat Review and Purchase Forum 7 05-22-2006 09:38 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
