08-27-2001
Caliber 33 / 35 Information
There seems to be a major structural problem developing with Caliber 35s. Some Caliber 35s have developed the beginnings of hull structural failure at the area where the hull joins the leading edge of the keel. Cracks will be found running transversely from the front keel edge outward and there may be a zone of cracks 1-2 ft. wide. Caliber has supposedly designed a small bulkhead for retrofit to avoid/remedy the problem to prevent the keel rotation from overstressing or overflexing the hull. A friend of mine had a Caliber 35 which was out of warantee, cracked, and got a lot of help from the factory, but still had to do a major structural hull repair. The problem is supposedly becomming common.
.... NOT a good light air boat.
