08-21-2006
Kevin-
Even on a new boat, 10-20% is not an unreasonable amount to have set aside for outfitting, re-fitting, repairing, upgrading, and customizing the boat.
Even a well-maintained and equipped boat will have a few things that the original owner did in a way that doesn't work for you. The boat has to be setup to work for you.
Lines being at the mast or led back to the cockpit are a good example. Some like the lines at the mast, others want everything lead back to the cockpit.
Electronics are another place where personal preferences might cause equipment changes. For instance, say the original owner had a non-chartplotter GPS, you might want to upgrade it, even though the existing GPS is perfectly functional.
New sails are another example. The current boat may not have any real light wind sails, like an asymetric or a spinnaker, and if you're planning on cruising, those sails are fairly important, as they are needed to take advantage of light breezes.
Electrical systems are another example. A well-maintained boat may not have enough electrical charging or battery capacity for the way you may want to use the boat. Adding additional batteries or auxiliarry charging systems are pretty typical. Solar panels, wind generators, a larger alternator are possible choices, although I prefer the panels and generator as they do not use precious fuel in the process.
Of course, you may luck out, and have the boat come to you in exactly the way you need it to be...but I kind of doubt that would happen. I'd also recommend you sail the boat a while before making any changes, to see if the changes you are thinking about, like leading lines aft, are really necessary or just something that you heard about and thought would be nice.
