T-4 years to 14 month sail...and buying - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 01-23-2007
camaraderie's Avatar
moderate?
Livia...congrats on getting a nice, strongly built boat! Enjoy her!!
  #22 (permalink)
Old 01-23-2007
Livia's Avatar
Vagabond in Training
Livia is on a distinguished road
Livia-
Congratulations... I hope you got a survey on the boat.
Definitely - do people actually buy boats (of this size and expense) without one? Wow!
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
  #23 (permalink)
Old 01-23-2007
Unfortunately, it seems more common than I'd like to believe.
  #24 (permalink)
Old 01-23-2007
yeah yeah yeah.....congrats on the boat..
Your signature is very uggly!!! Sounds wierd...can you write in english so I can understand it??
  #25 (permalink)
Old 01-23-2007
Looking's Avatar
Looking is on a distinguished road
Teak decks
While I am shopping for a boat, and I see one that I would like to investigate further... is there a way for me to determine a 'traditional' deck, from a 'glued' or 'mechanically fastened' one without getting a surveyor involved? It just might be a deal breaker for me, and I would like to be armed with as much knowledge as possible before I hire a surveyor. I mean, I might walk away from a mechanically fastened one before even thinking of the surveyor step.
"It isn't that life ashore is distasteful to me. But life at sea is better."
Sir Francis Drake
  #26 (permalink)
Old 01-23-2007
Unless the teak deck was recently done or the boat is extremely new, it is most likely a mechanically fastened teak deck... which can cause serious water intrusion problems... One easy way to tell if it is a mechanically fastened deck is to look for the bungs covering all the screws... A glued deck won't have bungs, a screwed down deck will.
  #27 (permalink)
Old 01-23-2007
Not exactly right, (I am really sorry to disagree with you), but it depends on the construction method.
Mine is screwed onto fiberglass deck with screws that have the cover as you mention, and is also glued with special whatever I don't know the name.
The screws were filled with sealant before tighteneing, and DO NOT protrude on the other side (interior) of my FG deck.
  #28 (permalink)
Old 01-23-2007
Giulietta-
It doesn't matter if you used sealant or that the teak is also glued down as well as screwed down... the screws pass through the top layer of fiberglass into the core, if your barge has a cored deck, and that is where the risk of water intrusion starts. Any holes that pass through the laminate into the core and are not potted with epoxy can allow water to enter the core and cause the core to delaminate.
On your barge, it may not happen since you hope they did the job properly and used sealant on every screw...but if they missed any...you're going to have a problem later on. I notice that the guys who did the work on your boat didn't bother trying to align the grain of the bungs with that of the deck to make them less noticeable... You obviously went the cheap route.
I doubt that IPWannabe is looking at brand new, custom-built boats for some reason.
BTW, IPWannabee...take a look at Giulietta's photos for what the bungs will look like, as he has a mechanically fastened teak deck. The second photo is the clearest as to what you will be looking for. If the deck is finished in any way, it may be harder to spot than it is in Giulietta's photo.
  #29 (permalink)
Old 01-23-2007
Giulietta-
SD my screws didn't go into the core, wich is divinycell and not wood, but I see your point. my outer FG lawyer is 4 mmthick.
Yes I would be concerned otherwise. He did a good job.
Maybe you want to re-phrase that barge thing, she made 17kts yesterday for at least 4 minutes, water speed not GPS.
Can you do that in your anorexic toothpick?? and point at 20ş, eheheheheeh
As far as aligning the grain, I specified that they were not...makes it sexy!!!
  #30 (permalink)
Old 01-24-2007
Looking's Avatar
No, looking for used... definitely!
NO. The IPWannabee is more tongue in cheek than anything. (Perhaps I should change my Username) I actually prefer a more classical look, and am especially enamored with:
Tayana 52, (1990’s) Aft Cockpit, Cutter rigged, teak decks, black hull!
Cabo Rico Cutter 42 and up!
Formosa…51 ya, I know it’s a project boat but they are beautiful!
Vagabond 47
With the exception of the Tayana, I seam to gravitate to the Ketch rigs... something about a bow sprit makes my heart sing!
Sir Francis Drake
Living aboard and learning to sail, or vice versa mark71565 Living Aboard 15 12-31-2008 03:23 AM
Boat buying advice for 35''+ range jmshack Boat Review and Purchase Forum 36 12-31-2006 12:53 PM
anxiety in buying a boat casey1004 Boat Review and Purchase Forum 35 10-29-2003 07:09 AM
Boat buying and learing to sail ogc Learning to Sail 8 08-21-2003 08:16 PM
Buying a sailboat arezba Boat Review and Purchase Forum 3 07-24-2001 08:35 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
