Update! - Page 2 - SailNet Community
post #11 of 14 Old 08-22-2006
yacht broker
captnnero's Avatar
Exclamation heads up !
Originally Posted by Plumcrazy
...What are the dangers of sailing with it this way in- say 10ft waves?
What you are talking about is failure of the support structure for the mast, so the whole rig could come down with even fatal results. Surviving that you've lost sail power too.
As previously stated, you need to get a professional opinion and estimate involved in this. You need to do that before the transaction proceeds to assess the financial viability including repairs.
captnnero is offline
post #12 of 14 Old 08-22-2006 Thread Starter
Ok- will do. By the way, on the original thread topic: I know what kind of boat it is- finally! This is an almost identical boat from the same year, aside from owner mods: http://www.boat-world.com/boatads/1132776946.html Thanks for the advice, and I will seek professional opinion before going any further with the purchase, as of now we are settled at $2,350, but I haven't entered in to a written agreement or made a down payment yet.
Plumcrazy is offline
post #13 of 14 Old 08-22-2006
maybe its just me.
there is no way on gods green earth i would even consider that boat, given what you've stated. run, don't walk.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #14 of 14 Old 08-22-2006
The compression post, and associated areas, are like the chassis of a car. They are structural not cosmetic. The spider cracks in the deck indicate it has been stressed, and if there is a plywood or balsa center core (which is typical construction) that may have been water damaged or collapsed over the years, so a repair begins with some testing on the deck to see if deck repairs are necessary.
Then you'd need to find out the correct length for the compression post itself, to see if yours is original/correct/damaged.
Last there is the compression post's "step" where it sits on the keel, or on a support over the keel, and that has to be in proper order.
When those are all correct, and the rigging is in proper tension (too much being as bad as too little) then yes, you can probably take 10' waves safely but remember that "small craft warnings" are intended for boats under 26 feet, and that means this one. Waves that size can be dangerous for this boat if the crew does not know how to handle them.
And with an outboard engine hanging off the stern (even with a long-neck engine, which is the only correct one for a sailboat) you'd be porpoising so badly in 10' waves, that you'd have no engine effectively. Again, not a problem if the crew and boat are up to sailing...but more than that boat should be out in.
When the structure has been neglected (as shown by the spider cracks) you can be sure there are other problems you haven't seen, and the sails are probably so badly worn out as to need replacement if you want the boat to sail properly. That may already cost more than you think, so please, find someone local who knows boats, and have them check it over with you.
Some folks would say it is a waste to spend $400-500 on a surveyor for a $2500 boat...but that's one option.
hellosailor is offline
Gorilla Glue on a boat? jr438234606 Gear & Maintenance 14 08-11-2006 09:52 AM
Catalina 400 Power Useage Fro36 Catalina 10 08-07-2006 12:02 PM
update alcohol stoves realitycaptain Gear & Maintenance 9 10-13-2003 06:40 PM
Cell phones and masthead antenna update mikehoyt Gear & Maintenance 6 09-06-2002 07:40 AM
update: moisture trapped between two gelcoat layers tappers Gear & Maintenance 1 01-12-2002 07:23 PM
