Peterson 46 - SailNet Community
post #1 of 9 Old 09-05-2015 Thread Starter
Picnic Sailor
chall03's Avatar
Peterson 46
We are currently looking at this boat.
Used Peterson 46 Cutter for Sale | Yachts For Sale | Yachthub
It is a Peterson 46. I am familiar with their reputation as a good value, well performing offshore boat but I am concerned that all but the most well kept examples are starting to get tired.
I will check the teak decks and also water tanks(apparently a known area of concern), beyond this what else should I be concerned about here?
How reliable are the the Ford Lehman engines? Am I wrong in figuring on re engining this boat?
Also happy for any and all general advice.
'Life is either a daring adventure or nothing' - Helen Keller
chall03 is offline
post #2 of 9 Old 09-05-2015
aeventyr60's Avatar
Re: Peterson 46
No Engine hours mentioned. Ford Lehman a very good marine diesel. At that price a good deal, but then what does it take to make it right.
Think you may have looked at Circe listed by BSS in langkawi. a lot more money, but very well taken care of.....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #3 of 9 Old 09-05-2015 Thread Starter
Picnic Sailor
chall03's Avatar
Re: Peterson 46
Yep....I think we would be definitely taking a look at Circe as well before we commit to anything...on the web it looks like a good boat for sure. Priority one is selling our current boat.
We had moved away from Peterson 44/46's but this one came across our radar simply because it is close by and again I am finding a lot to like.
It would be cheaper to buy in Langkawi and work on a boat up there than here. Highway robbery in Sydney and increasingly difficult to work on your own boat if you want to.
chall03 is offline
post #4 of 9 Old 09-05-2015
outbound's Avatar
Re: Peterson 46
Can't advise about the boat but did have a ford lehman back in the 90s in a S.H.E. 36.
Getting parts was torturous. One supplier on North Shore. Your supply chain is different and probably better than in U.S.. Actually working on engine was not bad. Did have to replace two injectors and high pressure pump but then ran fine. Was a bit hot if run a long time but probably due to heat exchanger not engine.
Maybe part supply better now and you probably have a bigger engine but hope that helps.
s/v Hippocampus
Outbound 46
outbound is offline
post #5 of 9 Old 09-05-2015 Thread Starter
Picnic Sailor
chall03's Avatar
Re: Peterson 46
Thanks Out.
In a thread on CF someone based here in Australia has expressed similar frustrations in getting parts here.
So not sure..
chall03 is offline
post #6 of 9 Old 09-05-2015
Bristol 45.5 - AiniA
Re: Peterson 46
The listing also does not indicate the size of the winches. One question I would have is whether I would want to sail the boat as a cutter or with a genoa. If the latter are the winches up to the challenge with the crew you have. I love the look of teak decks but they scare the crap out of me unless they have been replaced with the new glue on type. I have heard of similar problems with parts for the engine. We have a Westerbeke and the parts are often ridiculously expensive, but they are available. I just checked the value of the Aussie buck - ouch! It does make boats in US dollars pricey. When we were in Oz not that many years ago the Aussie dollar was above the US and Canadian,now it is bit less than the Canadian and way below the US.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
post #7 of 9 Old 09-05-2015
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Peterson 46
Have to admit that the teak decks worry me on a boat that old. Thickness is probably the best check and whether or not there is any sign of leaks below deck. While our girl does have teak decks I'd not specifically choose them. Look good when in good condition, look horrid when in bad. To be honest they are hot under foot though they do seem to help with insulation. Some years back we considered buying an older boat with teak decks but the cost and/or time and hard work involved in removing the old teak was outrageous. I must admit that I'm also no great fan of teak down below. That said the KP44/46 has a great reputation. Jeff_H is a great fan of them, I remember him once saying that for a world cruiser they would be right up the top of his list. Fabulous looking boats and apparently pretty rapid given their age and type.
Price certainly looks good. Engine parts I cannot comment on other than that there are a lot of oldish Grand Banks cruisers in Oz and from memory they have Lehmans ... or did have when new .... so maybe parts not so much of a problem.
One other thought, that is a big boat. Yes, I know there are now four of you but even so keep in mind the upkeep. Since moving from 34 to 42' I am gobsmacked by the extra dollars we now spend on run of the mill maintenance and the costs of upgrading hardware. I'd like to increase e.g. the size of our primary sheet winches but the cost gives me the heeby jeebies. Not to mention what new standing rigging is going to cost when that becomes necessary.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #8 of 9 Old 09-05-2015 Thread Starter
Picnic Sailor
chall03's Avatar
Re: Peterson 46
Thanks Killarney.....
Yes the poor little Aussie dollar.
It is also down significantly on the Euro. Which has impacted our boat shopping a great deal unfortunately.
chall03 is offline
post #9 of 9 Old 09-05-2015 Thread Starter
Picnic Sailor
chall03's Avatar
Re: Peterson 46
Thanks TD.
I have come across Jeff_H's write ups on them here in the past.
Have also spoken with an ex owner of a KP46 who had a lot of good things to say. The teak worries me. I find enough maintenance tasks on a boat without going looking for new ones.
I am very conscious of this.
I am also concerned about the practicalities of single handing such a large boat.
If I could just find a 40 footer that fit our tribe I would stop there, but we seem to be looking at bigger and bigger boats.
I wish we could just make it work on our Martzcraft but I don't think we can.
chall03 is offline
Peterson 46 Cherp General Discussion (sailing related) 2 09-25-2011 04:56 AM
anyone know anything about a peterson 33 tlscott Boat Review and Purchase Forum 3 06-22-2009 05:13 PM
Peterson kms Boat Review and Purchase Forum 17 08-23-2005 05:30 PM
Peterson 35 kms Boat Review and Purchase Forum 0 10-05-2001 06:36 PM
