08-31-2006
Personally, I would avoid buying a boat through the charter companies. The real problems I see with that are that the boats the charter companies want are often not laid out the way most private owners would want. If you look, you'll see a "charter boat" layout usually has more cabins, with fewer areas for storage. While more cabins sounds like a good idea...on most boats—less than 50' LOA, long-term travel with more than two couples is hopelessly optimistic. A family of four can cruise in a two-cabin boat relatively easily.
Also, it depends on what kind of sailing you want to do in the future. Most of the charter boats are coastal cruisers, without real bluewater capabilities. Most are of the "floating condo" variety—designed more for the stay at the mooring ball or dock than the passage between.
If I were you, I'd go for the small house, as you can always make it bigger later... and a large boat, but one designed specifically for your long-term sailing goals.
