Old 09-18-2006
Kerwood is on a distinguished road
Info on alerion express 28
I spent time at the Newport Boat Show this weekend and was very impressed with the Alerion Express 28. One of the feature changes to the new model is an increse in engine size from a 9 or 10 horsepower diesel sail drive to a 14 horsepower 2 cylinder model. The stated reason was better ability to motor in larger(6 foot or better) seas and high winds as reported by previous owners. While I am intersted in this boat a used model will provide a substantial savings over a newly ordered one. Are there any readers out there who own this boat with the smaller engine? What is your experience? If not an owner but familiar wth the boat and both its motoring and sailing characteristics I would greatly appreciate your input. I am hoping to take a demo sail later this week. Thanks,Kevin
Old 09-18-2006
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
She's a great boat to daysail on, well built by TPI now pearson composites(Freedoms & Pearson, and some little boat called a j/boat LOL) good workmanship, strong, but 80k for a used 28ft daysailor is a bit much for my blood. But, she is the prettiest girl in the harbor. (on the outside cabin is rather spartan... a cooler for the ingress/egress?)
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 09-18-2006
mstern's Avatar
mstern is on a distinguished road
I have only been on the Alerion at the boat shows; never sailed on one, although I did spend some time talking to the designer. One of the sweetest looking boats ever. Out of curiosity a few years ago, I tried to see what a used Alerion would cost. None were listed; maybe I'm not looking in the right places. Do you have a line on a used one? I'm not trying to cadge your potential boat, just curious!
Old 09-18-2006
can't re member
yotphix is on a distinguished road
yachtworld has seven listed at this moment!
Old 09-18-2006
No question she's a pricey dance partner. There are several used ones on yachtworld right now. Brand new the run north of 100k
Old 09-18-2006
Jeff_H's Avatar
Super Moderator
I have only had a brief sail on an Alerion Express. It was a pretty breezy day. I thought these were really nice boats that sailed quite well. The one that I was on did not have a traveler, which was really a problem in gusty conditions where it was important to be able to drop the traveller to balance the helm and reduce heel.
I personnally would prefer the middle of the three (or four)buildiing configuration (newer keel, but without the Hoyt boom which I personaly would consider a deal buster since you can't mount a bow pulpit or lifelines or conveniently use a genoa on a model that had the Hoyt jib boom.)
As to the engine, I had a 10 hp diesel on my 4100lb Laser 28. It was adequate in flat water, but speed obviously dropped off if you tried to motor into a strong headwind and seaway. The Laser 28 had more windage but less weight so it should be pretty equivillent. I usually chose to sail in heavier winds so the smallish engine wasn't much of a problem.
I personally had a tough time wrapping my mind around the overall concept of the Alerion. She is really pretty, and the double spreader rig imported directly from J-27 gives the boat plenty of go. They have purposefully simplified the Alerion down to the basics, but usually that means a boat that is economical to buy and own (like the Compacs for example). Instead, these are very expensive boats with a whole lot of compromises. The interior goes past being minimal. (My 1949 Folkboat had better accommodations). The deck hardware for example prevents the kind of tweaking that makes daysailing fun. The have an 'overnighter' interiod and yet they make no provision for even basic anchor handling and storage (the one I was on did not even have bowchocks.) I can't imagine sailing one in really heavy going, the narrow foredeck, and lack of lifelines returned myt to my youth, when lifelines were optional, and crew members routinely went over the side. At least the lifeline-less boats of the pre-1960 era had a grab handle that ran down the middle of the foredeck.
As perhaps, simply as a point of reference, less expensive similar concept boats, you might look at boats like the J-27 (same mast and boom), Laser 28, Express 27, or Goman Express 30 M.
Old 09-19-2006
avazquez's Avatar
avazquez is on a distinguished road
Beautiful classic lines + modern hull design = VERY EXPENSIVE $$$$$
Thats the equation that Alerion established, now others are following, Morris M36 is very very expensive too. So If you're a fan of classic shapes you have to find old classics and restore them. I guess there is a business oportunity for someone to produce a classic shaped sailboat at a reasonable price.
Old 09-19-2006
can't re member
You mean like a sort of PT cruiser for sailors? Not a bad idea. Affordable, nostalgic lines, relativlely modern engineering and a simple interior. And cheap. Like 50,000 dollars cheap. Do you supppose that's posssible?
Old 09-19-2006
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Since these pretty boats are built adjacent to my marina (TPI Portsmouth facility is on New England Boatworks property) and they're actually assembled on my dock, I have admired them for years. Iwould love to own one, but some day I may at least get to sail one.
True Blue . . .
sold the Nauticat
Old 09-19-2006
In the "spirit" of the Aileron Express concept, check out the link:
http://www.spirityachts.com/sy-spirit-46.htm
There is one of these in our area - the prettiest thing around - but is either harshly rated or poorly sailed, not doing well on the race course. Not that that matters.
These, too are pricey. Check the rest of the site for larger models.
Not practical, not cheap, but they get your heartbeat up a bit!
MacGregor 26x - info needed plz sailortaylor Boat Review and Purchase Forum 14 05-31-2009 04:05 PM
Info on Apollo,Trident Greek ex-charter boats etc. Myblueheaven Boat Review and Purchase Forum 0 09-07-2003 09:43 AM
Info on Express boats? CaptainSparky General Discussion (sailing related) 2 10-07-2002 05:59 AM
need rigging & sail info lace Gear & Maintenance 0 11-19-2000 12:16 AM
Need info on Tampa Bay area poosak Cruising & Liveaboard Forum 3 11-10-2000 04:31 AM
