Old 09-24-2006
bayouelton's Avatar
bayouelton is on a distinguished road
Send a message via AIM to bayouelton
Question Trivial Persuit for sailors
1) I'm watching Chased by Sea Monsters with Nigel on Animal Planet and he's filming from a 2 masted sailboat. Any body know the make, model, and year?
2) I just read the specs on one of the Beneteau's I'm thinking about buying (new) and it says "cast iron bulb keel." Now why the Hell would anyone make a cast iron anything that's going to go into sea water??? Wouldn't lead be much better?
3) Where are Cheoy Lees made and are they good boats??
4) I've heard that if you're thinking about a good used sailboat for the money (bang for the buck, so to speak) the best place to shop around is Hawaii? True or False.
Old 09-24-2006
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
Originally Posted by bayouelton
1)
2) Cast iron is a lot cheaper. They're usually coated but will rust eventually.
4) False
Rick I
Toronto in summer, Bahamas in winter.
Old 09-24-2006
sanctuarysam's Avatar
purveyor of mischief
sanctuarysam will become famous soon enough
cheoy lee is made in Taiwan i believe..there is a really pretty 36 ketch in annapolis..she is a bit old (1969)..but in really good shape..if you don't mind a boat loaded with brightwork...loads of creature comforts below if that's your gig..
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
Old 10-08-2006
bayouelton's Avatar
1) While looking around at used sailboats I came across this one at Rough and Ready Island (Stockton, CA). Don't think I could use one this old or handle one this big, but anyone want to take a guess-timate on how old this boat is? (sorry for the poor quality - my phone was the only camera I had at the time).
2) I was reading in the news about one of the Hewlitt Packard board members (re the corporate spying scandal) and the article said he lived on a $295 million sailboat!! A SAILBOAT!!!! For two hundred ninety five million bucks!!???? Was that a misprint?
http://www.sailnet.com/forums/attach...1&d=1160309164
Old 10-08-2006
Jeff_H's Avatar
Super Moderator
1. Never watched Animal planet so I don't know,
2. Properly formulated and cast, cast iron is a reasonable form of ballast. In the early 20th century, seen as being stronger than lead, cast iron was the preferred keel material for offshore sailing. In a grounding the cast iron keel was seen as less likely to be damaged, and so is often the keel material of choice for a charter boat.
On the flip side, lead is more ductile than cast iron and so can absorb impact by deformation, therefore transfering less impact into the hull and supporting structure of the boat.
The Europeans still seem to prefer cast for many applications, using on a lot of their boats including some pretty expensive ones. Cast iron is less expensive as well, but that savings is somewhat offset by highter costs to fair and finish the keel. Cast iron is also showing up in race boat keels for the foil portion of the keel, and then lead is used for the bulb.
When you talk about maintenance on cast iron, you need to ask whether this is a bolt on or encapsulated keel. Beneteteau uses bolt on keels. In my opinion cast iron should never be used in a encapulated keel. Leakage into the encapsulation is almost always inevitable and the surface corrosion that forms will cause more repid wide spread delamination of the ballast from the encapsulation.
It is a little bit different story with bolt on keels. The fairing materials used on both lead and cast iron keels have a limited lifespan. With lead that lifespan is generally longer than that of the same fairing materials used on cast iron. At minimum, as a part of routine maintenance small nicks in the fairing material should be patched with a zinc rich epoxy, covered by a barrier coat. With cast iron repairing the coating at haulout becomes much more crititical to the long term condition of the fairing material. When it comes time to refair the keel, the process is considerably harder to so as the casting tends to be much more irregular. Opinions on technique vary, but my favorite is some variation of sandblasting the iron 'white' and immediately coating with a zinc rich epoxy. Then build up an epoxy based fairing material to the proper contour, final fair, and barrier coat. That should be a 10 to 15 year solution if done well.
From a yacht design point of view, cast iron is substanially less dense than lead. In modern designs this typocally translates into more drag for a given stability. Beneteau uses cast iron predominantly on their shoal draft boats perhaps figuring that a person ordering a shoal draft keel is less concerned with drag and stability than someone who orders a deeper draft keel. In some ways I think they have it backwards.
Cheoy Lee is one of the more highly respected Asian Yards. This is a very old company based in Hong Kong (not Taiwan). Their build quality is difficult to categorize as it has changed greatly over the years and from model to model. Thier boats often have extremely high quality elements mixed in with items that are of dubious quality. I like some of their designs, (I once worked on drawings for a 53 footer that they built).
4. From what little I know, the listings for boats that I have looked at that were in Hawaii tended to be more expensive than mainland boats. It used to be that there were very cheap prices for boats in New Zealand and Austrailia but that seems to have changed dramatically.
second post,
1. That looks like it might be either a Murray Peterson Coaster series, which were mostly built in the 1940's to 1950's or it is Angleman which were built as late as the 1960's. Of course it could be something completely different. The photo is not clear enough to tell.
2. I suppose that it is possible to build a Mega Yacht for 300 million, but I would suspect that most megayachts are well below $100 million. Who Knows.
Old 10-08-2006
bayouelton's Avatar
Thanks for the reply Jeff. A very interesting and informative set of answers. I didn't mean to sound surprised that there are $300 million mega yachts out there. I just didn't expect them to be sailboats.
Old 10-09-2006
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Can't help you with the schooner I'm afraid although if she's plastic then one would would hazard a guess at some kind of Cheoy Lee.
I think the super yacht you are talking about is the Maltese Falcon. Largest privately owned sailing boat in the world I believe but the guff I've read about her suggested buckazoids more in the hundred to hundred and fifity million range.
Old 11-26-2006
bayouelton's Avatar
Talking Oops!
Originally Posted by Jeff_H
second post,
Guess I'm a little late getting back about this with a little egg on my face here, but I finally heard from someone at the Stockton Yacht Club and it turns out that the pic I posted was of nothing more than a prop built for a Hollywood movie. The present owner bought it to convert it into a real sailboat and supposedly got nowhere fast. It's been sitting there in the water for more than the last ten years.
Anyway, I got another question here. I just saw an interesting segment on Discovery's I Shouldn't Be Alive. It was about a crew delivering a sailboat from Maine to Florida. Does anyone know if the way it was presented on TV is the way it really happened? Was poor seamanship involved or was it just bad luck? Was there anything the skipper could have done to prevent capsizing? And does anyone know the size / make of the sailboat involved? If I heard correctly the narrator kept calling the boat "The Trashman." But I did a Google search on that name and got nowhere.
p.s. - if anyone knows the movie the prop was in, now that would be impressive
