White vs. coloured hulls - SailNet Community
post #1 of 9 Old 10-14-2001 Thread Starter
Anyone with a Jeanneau Sun Odysssey painted blue hull? About to invest but was recently told the dark blue painted Jeanneau hulls tend to scuff really easily. Any comments.
Jon Conway is offline
post #2 of 9 Old 10-15-2001
Moderator
Jeff_H's Avatar
I have no direct knowledge about dark hulled Jeanneaus but in my experience with my own dark hulled boats, I found that the boat tended to get coated with salt as water flash dried on the topsides much easier than my white boats. This meant that I was scrubbing the hull more frequently and that the fenders were more likely to abrade the hull where the fenders rolled back and forth on the hull. As a result, I was waxing the hull three or four times a year to keep the boat looking bristol.
Although I believe that dark hulls are a lot more maintenance I just bought a boat with a dark blue hull. That said, at some point I intend to have the boat painted white.
Dark
Jeff_H is offline
post #3 of 9 Old 10-15-2001
Moderator
Jeff_H's Avatar
BTW Is this the Jon Conway formerly of Annapolis?
Jeff_H is offline
post #4 of 9 Old 10-15-2001
RichH's Avatar
Being the former owner of a dark blue hull, I perceive that there are other issues that would suggest the avoidance of a dark fiberglass hull. Unless the hull was specifically and originally layed-up as a dark hull and has ***sufficient/extra thickness of matting underlayment*** of the gelcoat, there will be eventual additive thermal deformation and dimensional changes of the surface as evidenced as "print-through" of the fiberglass roving, etc. or surface wrinkling. Most of this print-though may be cosmetic but some other dark hulls I''ve noticed seem to have accumulated/additive structural deformation where the dark hull intersects a bulkhead and/or chainplate attachments, etc. ---- very visible deformations. Simply take a walk around any boat yard and especially look at the older dark hulls (especially those constructed with fiberglass roving) ..... most are wrinkled and have ''print-through'' and other surface deformation. As one with an extensive stress analysis background, I perceive this is not good!. I further perceive that the base polyester polymer on a dark hull continues to additionally cure because of cyclic high thermal stress (constant heating and cooling) thus causing the print-through, wrinkling, and perhaps even structural anomolies. I understand that in the past, several manufacturers of cored composite hulls have had many problems (weakened laminate) with dark colored hulls - Niagara, etc.
But they are Pretty.......... until you eventually paint them white. :-)
RichH is online now
post #5 of 9 Old 10-15-2001
Hi Jeff
no I am from the UK living in Hongn Kong.
Cheers!
PS Thanks for the feedback.
jonconway is offline
post #6 of 9 Old 10-15-2001
Thanks Rich
Wow pretty technical stuff. I simply think they look prettier than ''plain'' white , but seems the opinion is they should be avoided. Pity!
Cheers
Jon
post #7 of 9 Old 10-18-2001
I have my boat on the hard right now, and
one of the things I had planned on doing was painting the hull navy. Is this a bad
idea?
thomas s is offline
post #8 of 9 Old 10-18-2001
My first boat was a beautiful dark green. I rubbed against a dock, putting some scratches in the color. I told myself then, I would never buy another boat with a colored hull. My next boat was and is navy blue. I just couldn''t resist, they are just so good looking. (I also bought 10 bumpers to avoid any scratches) Jeff is right, i have to wash the hull down every other week and wax a few times during the season or the salt makes it look dirty. But i think its worth it.
Rob
rmelvin1 is offline
post #9 of 9 Old 10-18-2001
Thanks! I was starting to get worried. I
have always admired the sailboats with
colored hulls. I cant wait to paint my hull navy. thomas
thomas s is offline
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 03:23 PM
Hobie Hulls oldcat Gear & Maintenance 2 04-01-2004 03:53 PM
Balsa cored hulls - old boats gstraub Boat Review and Purchase Forum 20 02-21-2003 05:08 PM
Are Col hulls cored? mrb2222 Boat Review and Purchase Forum 4 01-08-2002 03:59 AM
Looking for Chuck White kopykatps Cruising & Liveaboard Forum 1 05-02-2001 05:50 AM
