tartan34C questions - SailNet Community
 1Likes
  • 1 Post By cockedhat
post #1 of 7 Old 05-31-2016 Thread Starter
flo617's Avatar
tartan34C questions
Hello,
I wasn't planning on a major upgrade from my boat but I came across a tartan34C and I could not resist the temptation.
I visited it yesterday and I have a couple question:
1/ How painful is it to take care of the centerboard? I have read about the issue with the pin. Is overall maintenance painful?
2/ I came across some bolts at the edge of the deck which had no nuts (see pictures attached, they are dark sorry, you can see the bolts on as dark sticks on both images). What is that about?
Thank you!
PS: What gorgeous boats.
flo617 is offline
post #2 of 7 Old 05-31-2016 Thread Starter
flo617's Avatar
To be precise regarding the pictures, it's the starboard side, behind the cabinets above the seats/berths in the salon.
Also, in this area, there is what feels like butyl tape at the hull-deck area. Is it what tartan used?
flo617 is offline
post #3 of 7 Old 06-01-2016
JimsCAL's Avatar
Re: tartan34C questions
I suspect the bolts are hull-to-deck joint. I seem to remember that Tartan sometimes embedded a strip of metal into the structure and tapped it for the bolts rather than using nuts.
JimsCAL is online now
post #4 of 7 Old 06-01-2016
On the Tartan 30, under the jib lead tracks there is an aluminum plate embedded in the deck. The screws don't protrude thru the deck however. Your pictures are a little hard to see. Do these screws appear all the way around the boat or just in that area? Port and Stb?
On many of my deck to hull joint screws/nuts you can't see the nuts because they are covered in fiberglass, but the nuts are under there.
s/v Harmony
1973 Tartan 30 #186
Anchorage Marina, Baltimore MD
oldlaxer1 is online now
post #5 of 7 Old 06-01-2016 Thread Starter
flo617's Avatar
That's the starboard side. I could not see everywhere because the cabinet ends usually hide the joints and some sort of thin liner does that on other places like the v-berth and quarterberth.
The other picture I have shows some in the stern with various levels of penetration.
flo617 is offline
post #6 of 7 Old 06-01-2016 Thread Starter
flo617's Avatar
Sorry for the quality of the pics. You can see one bolt protruding clearly on the left, then one protruding less, then two on the right, barely showing. They are stainless steel.
flo617 is offline
post #7 of 7 Old 06-02-2016
The bolts with no nuts go through a piece of Al flatbar that is glassed into the hull flange and tapped to take the bolts. The centerboard pin replacement isn't all that difficult, and may not even need to be done; depends on whether the board droops when in the raised position. There is quite a bit of information on the T34C website pertaining to it's replacement/refurbishment. Other than the pin, and possibly replacing the pendant used for raising and lowering the centerboard there is very little maintenance to do to the board. I had a T34C that I sailed from the east coast of the US to New Zealand. They are great boats, and highly underrated as a good, inexpensive cruiser.
seabeau likes this.
cockedhat is offline
The Following User Says Thank You to cockedhat For This Useful Post:
flo617 (06-02-2016)
S2 9.2A questions JIvories S2 13 01-31-2016 08:33 PM
A few more questions GenesisCaptain Gear & Maintenance 3 04-10-2010 09:26 AM
Many Questions Gorlog Gear & Maintenance 8 11-25-2008 10:44 AM
About To Do It Questions Jack7 Living Aboard 18 02-26-2004 09:31 AM
