Yanmar 2GMF Fuel Mystery - SailNet Community
post #1 of 1 Old 06-04-2016 Thread Starter
I can hand prime with the lift pump the secondary and injector pump bleed screws. Engine starts and runs for 3-4 minutes then stops.
The secondary fuel filter cup is almost dry. The engine uses the secondary filters fuel and stops when its empty.
I have replaced fuel lines, primary fuel/water separator, new lift pump
filters and have spent much time looking for leaks etc.
It was suggested that the lift pump arm goes under the cam inside the engine. I have the new lift pump arm against or on top of the cam. What is correct?
It seems the lift pump is not pumping fuel to the secondary fuel filter as the engine runs.
Any help will much appreciated, Thanks!
Capt Mulch is offline
Yanmar 2GMF Help Capt Mulch Diesel 2 05-29-2016 08:08 AM
Yanmar 2gmf winterizing? nathan007 Gear & Maintenance 7 09-07-2015 09:05 AM
Yanmar 2GMF problems Kiltmadoc Diesel 6 08-22-2012 02:46 AM
Yanmar 2GMF fuel sheen from exhaust. grifftrad Diesel 4 05-16-2012 09:46 PM
Looking for a used Yanmar 2GMF or? captsam54 Diesel 0 08-09-2009 03:43 PM
