  #11 (permalink)
Old 05-27-2008
rugeley is on a distinguished road
does anyone have any experience building or rebuilding spruce spars?
  #12 (permalink)
Old 10-13-2008
karsurf is on a distinguished road
no, and i'm scared
I just de-masted and will start to rebuild soon. how did you fare?
ken
  #13 (permalink)
Old 01-15-2009
FourSeasMilford is on a distinguished road
Choey Lee masts are built of four pieces of Sitka spruce- the glue line is the most likely point of failure. If you inspect the mast very carefully, you can usually catch the glue failure early and re-glue easily. Go to West Marine, get some Git Rot, clran out any loose material and let the Git Rot flow into the opening. You may have to go over the glue line a few times before the Git Rot fills the crack level withe surface. For larger cracks, you may need to push some thread down to create a dam so that the Git Rot has a chance to soak in and set up.
I owned a CL Newell Cadet for almost 20 years and never had a problem with a glue line repaired with this method.
  #14 (permalink)
Old 01-15-2009
Jeff_H's Avatar
Super Moderator
I have repaired a number of glued up spars, including a Cheoy Lee boom. I would like to respectfully comment on the post by fourseasonmilford. I would agree that failed glue lines are likely to be the first indication of problems. That said, very often by the time that the glue lines begin to visibly fail moisture has gotten into the hollow in the spar and the wood is rotting from the interior of the mast outward greatly reducing the strength of the spar. Care should be taken to allow the spar to dry out in a protected shed before attempting repairs. I would also suggest that GitRot is a diluted epoxy with mediocre structural characteristics. I would suggest that a better choice would be a structural epoxy like MAS or WEST System.
  #15 (permalink)
Old 09-08-2009
ehatch is on a distinguished road
Hi all...like Jeff I'm "trying to like" Cheoy's too. Are there ANY models made at the Cheoy Lee shipyard that might be worth considering?
  #16 (permalink)
Old 09-08-2009
sailordave is on a distinguished road
The folks across the dock have a CL 31. Pretty to look at but....
They dunno go to windward at all.
As much as I love wood boats (all wood) the thought of taking care of the varnish work on a CL gives me the willies.
  #17 (permalink)
Old 09-08-2009
yeahhhh...
I'd rather be spending time on the water instead of varnishing, especially as my window for sailing time here is so limited. I initially became interested in these after finding an add for a flyer....then another add for a cadet. Seems like such a well known shipyard would have at least one outstanding model.
So many boats....so little time!!!
  #18 (permalink)
Old 09-09-2009
mitiempo's Avatar
I agree - a lot of work to maintain. Best to own a lower maintenance boat and get a berth next to a classic so you can look at it, discuss varnish types with the owner, and then go sailing.
Here's the kink to the Cheoy Lee Sailboat Association Cheoy Lee Sailboat Association Page2
Jimmy Buffett used to have one, I believe it was a Clipper 42. Used to keep it in Margaritaville I think.
Brian
Cheoy Lee Offshore 41 FrankDowney Boat Review and Purchase Forum 3 03-03-2012 08:21 PM
Cheoy Lee Offshore 40 Ganderbay Boat Review and Purchase Forum 29 09-24-2010 11:44 AM
Production blue water boats JakeLevi Boat Review and Purchase Forum 73 07-31-2009 10:07 PM
Bluewater defined? dch Learning to Sail 44 07-29-2009 07:20 PM
Cheoy Lee Offshore 28 islandman2 Boat Review and Purchase Forum 4 06-14-2006 08:42 AM
