Blogs
User Name
Old 12-05-2006
BADG's Avatar
BADG BADG is offline
BADG is on a distinguished road
Centerboard Recs
Until recently I had not given CB's much consideration but I have a standing offer to rent private dock space. The location and $$ for this particular dock space is worth considering in the decision and process of buying a boat. The problem is that deep water is limited so I thought a CB would be the way to go. From what I've been reading CB's are not the enormous compromise I thought they would be but my knowledge on specifics is limited.
Any centerboard models that stand out as particularly well made, functioning and performing?
Old 12-06-2006
BADG's Avatar
Any input on the Scheel Keel would also be appreciated. Is this a good idea gone wrong, a looks better in theory than in practice kind of thing.
I notice Tartan 33's use them and that combined with a cored hull makes me weary.
Old 12-06-2006
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul is a jewel in the roughcardiacpaul is a jewel in the roughcardiacpaul is a jewel in the rough
take a look at the Freedom Cat/Ketch, most have CB's...
Making a decision on what boat to buy based on a good deal at a dock is a new one on me.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Sponsored Ad
Old 12-06-2006
BADG's Avatar
Yeah I know it sounds dumb and it wasn't my original plan but dockage/moorings are slim to none and expensive. I'm not sure I'm changing my plan yet but looking into what it would mean to do so hence the inquiry about Keel/CB's and Scheel Keels.
Old 12-06-2006
ehmanta's Avatar
ehmanta ehmanta is offline
Sailing Junkie
ehmanta is on a distinguished road
Centerboards
There are a few manufactures out there who have been building centerboarders for decades....Bristol, Hinckley, Tartan, Morgan Etc...
I own a Tartan 37 with a board, draft is 4'-2" and she can sail quite well with-out the board down. The CB gives her pointing ability, but no noticable stabilty gain.
If money is a great concern, look at an older Tartan 34 or a Morgan 34, both only draw about 3 1/2 feet with the board up.
Old 12-06-2006
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie is a jewel in the roughcamaraderie is a jewel in the roughcamaraderie is a jewel in the rough
Ehmanta gives you good advice. The only only thing I would say about a wing keel is that you will need good towing insurance cause when you go aground you will be there till the tow boat comes along! I would much prefer a shoal draft long fin keel or K/CB boat if you need to get in and out of skinny water.
Old 12-06-2006
pigslo's Avatar
pigslo pigslo is offline
pigslo is on a distinguished road
center boards
I own a centerboard that draws 4 feet and 9 with the board down. I have taken the boat offshore and she sails like a demon upwind. 99% of the time, the board is almost up,( will drop the board down a foot or so to close up the hole and present a more fluid shape to the water). When in skinny water the board gets pulled all the way into the trunk. While a winged keel is probably a better way to acomplish shallow draft from a mechanical standpoint, those times when wanting to point up high are fun but I am not sure it is worth it. My boat was built with a 5 foot draft keel and no centerboard and I have considered that keel modification at times. I suppose the prevailing depth in your cruising grounds are a big factor in determining your decision.
Pigslo
Old 12-08-2006
BADG's Avatar
The decision to be made is A) travel further to marina (45-60 minutes) but not be overly concerned with skinny water or B) have real close boat storage that is affected by skinny water and may require shoal draft.
I am looking for a 28-34 footer to daysail, w/ overnites and week long cruises a handful of times during a season. I don't want spartan accomodations but I don't need a condo at the sacrifice of performance either. I'm considering Sabre, S2, CS, Tartan, C&C and Pearson simply because I have limited experience on each. Sabre and Tartan are in the forefront due to companies still in business and rabid owner support. Would love a Sabre 34 w/ CB but may be too pricey.
I have an eye on a Tartan 33 but as I mentioned previously cored hulls and a scheel keel (no experience with one) concern me. Anybody with experience with this boat care to weigh in?
Old 12-11-2006
ehmanta's Avatar
Sailing Junkie
cored hulls
Yes, sometimes the coring can get water infiltration. My Tartan has partial coring only in large panel areas. The areas subjected to impact or where structural members are joined is solid glass. Also the outer skin of fiberglass is quite significant, the wood core just adds a bit more stiffness. Long story short, Tartan knows how to core a hull. I am not experienced sailing a scheel keel, but Tim Jackett (Tartans in house designer) still designs with them on their shallow draft boats so they must be efficient, at least better than a wing.
Old 12-11-2006
CBinRI's Avatar
CBinRI CBinRI is offline
CBinRI is on a distinguished road
I don't know what you want to spend but Tartan has always made good use of the CB. You could find an older 37 in the 50s or 60s with recent and bigger models going way up from there.
vB code is On
Centerboard for Morgan 34 m34 Gear & Maintenance 20 10-01-2008 12:04 PM
Morgan 22 Centerboard + Swing Keel Restoration briceburg Gear & Maintenance 4 09-23-2007 06:51 PM
Ericson25 Centerboard brbsim Gear & Maintenance 7 09-23-2006 12:16 AM
Centerboards and Swing Keels Bruce Caldwell Buying a Boat Articles 0 05-04-2004 09:00 PM
Centerboard Tradeoffs Mark Matthews Learning to Sail Articles 0 12-02-2001 08:00 PM
Page generated in 0.7899 seconds (76.40% PHP - 23.60% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
