12-25-2006
There is some reported build quality variation in the Force50/Formosa51 boats, although I haven't seen that in my limited experience with the boats. The Hudson variety (Hudson, Hardin and Formosa all built versions of the same model) seems to have good build quality regarding most aspects. The boats were built in a couple of yards (see applicable post on www.force50.org). As with any boat 25 years old, the influence of owners over that period of time has had a significant effect on it's seaworthiness and finish. It's a heavy boat, seakindly in a blow and comfortable to sail. While it's heavy it easily moves along in proper trim, usually at 1/2 to 3/4 of the wind speed depending on point of sail. It's a full keel and low speed handling isn't great. Like many heavy cruisers, tacking takes some finesse and backing under power is more of a throttle manuever than a rudder. Lot's of room inside and on deck, very easy to move around on deck in lumpy seas unlike some boats that present an obstacle course.
Things to check thoroughly during survey: If teak deck, pull some screws and check deck core for moisture. If it still has spruce spars, check those out. Electrical systems should be checked thoroughly. Many of the boats built in late 70's had steel fuel tanks, check for corrosion.
Jim
