Old 01-25-2007
castoff is on a distinguished road
Engine question
Does "Volvo penta 3cyl. 28hp diesel, 2003 series model" mean that the engine was new in 2003.
I suppose a lot depends on how well an engine was maintained, but how many hours is reasonable for a diesel engine. Is 2700 hours on a '94 Yanmar 3GM Ok.
Old 01-25-2007
k1vsk will become famous soon enough
Yes and absolutely yes regarding maintenance being the salient issue, regardless of engine hours. A well-maintained '94 Yanmar with 2000+ hrs on it is much preferrable to a similar year, similar engine with 500 hrs on it with little routine maintenance and infrequent use at low RPM.
Obviously, if your question is in the context of a potential purchase, a thorough engine survey is a good idea, regardless
Old 01-25-2007
Goodnewsboy is on a distinguished road
You have asked a couple of questions.
1. I do not know what is meant by "2003 series model". It sounds like salesman talk.
2. 2700 hours works out to over 200 hours per season for 12 years use and is quite a lot in an auxiliary sailboat, probably indicates a southern boat.
3. A Yanmar (I own a 2GM) ought to be able to give good service with that number of run hours, provided that it has been maintained and serviced properly. A lube oil analysis and a compression check will help to verify its condition. Be sure to check condition of the cooling system very carefully, especially if it is raw water cooled.
Old 01-25-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Engine hours alone are not always a good barometer. Some with high hours, but good maintainance, can be in much better shape than one with low hours and poor maintainance. Also, how the hours were put on is a factor. One run primarily to charge batteries (ie: low rpm, no load) will be more problematic than one used to motor with.
So it's hard to say, just on hours alone, what shape an engine is in. Diesels can be remarkably long lived, if taken care of properly. And short lived if not. If this concerns a boat you are looking at, I would have an engine survey done.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 01-25-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
From what I was told, the "2003" has nothing to do with the year, for Volvo its just a model number. I looked at a boat that had a 2002 model, the engine was built in 1994.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 01-25-2007
PBzeer's got a good point... Diesel engines are more likely to die of neglect than over use. Using one too few hours usually means it is neglected... since it usually extends the time period between maintenance checks.
Old 01-25-2007
I think that's correct - 2001/2002/2003 are 1,2,&3 cylinder models of that series of Volvos.
And to add to PBs point- engines that have sat unused for long periods of time can have compression issues because the rings can stick in the piston head and not seal on the cylinder wall properly. You could be better off with a well maintained motor that's been run regularly (and has hours on it) than an old low hour engine.
Old 01-26-2007
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
The 2003 is a 3 cylinder engine in the Volvo 2000 series. There was the 2001 (single) 2002 (2 cylinders) 2003 (3 cylinders) and 2003T (3 cylinder turbo). These engines were manufactured from about 1984 to 1990. They were the worst engines Volvo manufactured as can be noted by the short run. Volvo claimed they were the state of the art at the time but I think they were more experimental. After these Volvo stopped manufacturing small block diesels and assembled them using I believe Kubota blocks or they repainted Perkins small diesels. I would not buy a boat with a 2000 series engine unless the cost of a new engine is factored in.
2700 hours on a 3GM would not worry.
Rick I
Toronto in summer, Bahamas in winter.
Old 01-26-2007
Not to be redundant as in some of the prior posts, the conventional wisdom is to do an engine oil analysis as part of a survey of the engine. It is, however, essentially meaningless, as a stand-alone result. To be of any real use in determining engine integrity, it has to be done on a routine basis such that any trend(s) can be observed which would be the only significant indication of engine problems.
You will find many people who believe the inaccurate marketing of this analysis or just don't understand the chemistry of an engine which is wearing improperly. It is both misleading and a waste of money to do an engine analysis unless you have multiple previous analyses with which to compare it.
I could go into the years of experience I've had with this hype, the lack of QC of various labs which do these analyses as well as their lack of precision and reproducability of the results and the meaninglessness of the results, all of which is pretty boring so I'll save that if anyone cares for later.
Old 01-26-2007
camaraderie's Avatar
moderate?
K1...so then, how do you best evaluate the condition of an engine you are about to buy? Run it and watch what happens and compression test? Or is there something else you would do?
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
