Old 01-30-2007
ianbass's Avatar
ianbass is on a distinguished road
hunter 27
i am looking at a 1990 hunter 27 it is in great shape, it has no damage, it seems to have been taken care of. dose 15,500 sound like a good price?
Old 01-30-2007
pigslo's Avatar
pigslo is on a distinguished road
You can go to yachtworld.com and search the listings. You should find enough listings to compare price.
pigslo
Old 01-30-2007
Cruisingdad's Avatar
Best Looking Moderator
You might also consider other boats of that era, including Catalina and beneteau. However, I think they will be more expensive.
- CD
Old 01-30-2007
ASA and PSIA Instructor
Hunter is a low budget boat builder. For that kind of money for a 27 you should consider better quality boats. Cal, C&C, or Catalina all provide better design and construction for that money.
Take a look at this review of a Hunter 28 http://www.yachtsurvey.com/boatreviews/hunter28.htm and it should answer any questions as to why I offer this advice.
Old 01-30-2007
sailortjk1's Avatar
Do all Hunters have cored hulls? I think some of them do. Not sure about that era.
I would check into that, I am not a fan of cored hulls. A cored hull can trap moisture and become a large head ache. I would check that out, and of course a survey would indicate if there was any problems.
Old 01-30-2007
SailingFool,
I think you and i share the same feeling (I was just trying to say it a little different!!). The later model Hunters seem to have a better rep, but it was the 90's that a lot of people got burnt. Ian, if you are reading this, your boat might be fine... it might not. Given the cost difference between your boat and that of other Hunters of the same vintage, I would be conscerned you are in the wrong crowd... or maybe it is just the deal of a lifetime (er, hmm)????? But if you are going to drop what would be in the mid 20's or so... you should do more research on the merits of other boats, including Catalina, which have a more solid reputation with many people. Beneteaus are solid, C&C, and too many others to mention. If you are stuck on that particulair boat as the 'boat of a lifetime', well, get a good survey.
- CD
PS Not trying to sound negative to you or any other Hunter owners... no offense please.
Old 01-30-2007
To the best of my knowledge, Hunter does not use cored hulls any models. any years, nor does Catalina, Cal, or Beneteau.
Old 01-30-2007
sailortjk1's Avatar
I saw a cored hull on a boat that sunk last fall, it was paper thin.
She was in a local yard after hitting the bottom last October.
The hull was diffinetly cored, you could see the sandwich after she was ripped wide open.
Edited post....
Found this from a review of a 2006 49'. I wanted to make sure I was not going crazy.
"Forward sections of the hull have been reinforced with Kevlar. The hull sides above the waterline have a Balsa core, which makes for a lighter hull and also adds both sound and thermal insulation."
Old 01-30-2007
Cored hulls above the waterline are far different than cored hulls. Some boats, like the southern cross 31 have cored hulls... even below the waterline. While the SC31 is an excellent boat, if there are any problems with damage to the glass below the waterline or with improperly installed thru-hulls, the results can be very, very expensive to repair, when compared to what would happen on a non-cored hull or one that is not cored below the waterline.
Old 01-30-2007
pigslo's Avatar
Trust me that Hunter 27 is not kevlar reinforced.
pigslo
hunter vc mac jeffwas Boat Review and Purchase Forum 16 12-11-2009 08:43 PM
Hunter 306 Cobraman Boat Review and Purchase Forum 6 02-10-2008 07:43 PM
A New Hunter 49 and an Old Traditionalist dawndreamer Boat Review and Purchase Forum 22 01-01-2007 09:32 PM
Hunter Vision 32/36 offshore? newtoschool Boat Review and Purchase Forum 17 10-27-2006 07:27 AM
The Hunter 420 Micca Hutchins Buying a Boat Articles 0 10-07-1999 08:00 PM
