Pearson 30 vs. Cape Dory 25D? - Page 2 - SailNet Community
post #11 of 24 Old 02-12-2007
Of course, Randy might be a bit biased IMHO...
I'm going to throw another possibility out there... the Alberg 30... it is about the same size interior wise as the Pearson, but is a full-keel, very stable design, much like the Cape Dory 25D, by the same designer—Carl Alberg. Another possible choice is the Cape Dory 30... also, an Alberg designed boat IIRC. I prefer the Alberg 30 over the CD30 for one reason...tiller steering. The CD30 has wheel steering..
sailingdog is offline
post #12 of 24 Old 02-12-2007
randy capedory 25d seraph
You better know I'm biased toward Cape Dory. Having had my 25D out in 45kts and seeing how she handled it, I was sold on the full keel, narrow hull. That day when it was still only blowing 25-30 I beat both a Benatua sp? 32 and a Hunter 30 to windward by quite a bit. And here's the shocker, they were both using their main and headsail, while I only had my 130 headsail out. And it gets better, they were heading in (too much wind coming they said later). I headed back out and had a heyday. All in my little 25D. And they were both fully crewed, I was singlehanding!
All of Carl Alberg's designs are boats I'd own. He knew how to draw a very seakindly hull.
rtbates is offline
post #13 of 24 Old 02-12-2007
ASA and PSIA Instructor
Originally Posted by rtbates
.....only blowing 25-30 I beat both a Benatua sp? 32 and a Hunter 30 to windward by quite a bit. And here's the shocker, they were both using their main and headsail, while I only had my 130 headsail out. .......All of Carl Alberg's designs are boats I'd own. He knew how to draw a very seakindly hull.
I guess every dog has its day, or moment anyway.
sailingfool is online now
post #14 of 24 Old 02-12-2007
Wandering Aimlessly
PBzeer's Avatar
The 25D is a perfect TWO person boat
While not to dispute the qualities of the CD, they did say a Family of Four, for weekending.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is online now
post #15 of 24 Old 02-12-2007
Windy Days
As I recall, LI sound has many more light air days than breezy days. CD is an ocean going vessel...and you're not really in the open ocean. P30 is a real good Chevy...but I would take the rest of winter and check out S&S boats like the Tartan 30 or the C&C 30 (I know not an S&S, but great boat nonetheless). This would put you in the "Buick" level.
Moe
mgiguere is offline
post #16 of 24 Old 02-13-2007 Thread Starter
CLucas's Avatar
Send a message via AIM to CLucas
So if a P30 is a "real good Chevy"...
Moe
..what is a Catalina... or a Hunter? Not looking for an answer, but go ahead if you feel like chiming in . Good advice and comments all -- I'm probably a bit biased myself towards CD's since that was what I grew up sailing. Stiff as a church but definitely not breaking any speed records. Checked out a squeaky clean CD 25D last weekend -- way too tight for my wife and two young girls. A clean CD 30 is out of my budget.
Looking at 2 comparable P30s - same vintage, *similarly* but not identically equipped -- one with tiller steering and one w/wheel for starters. Of the two, the one with tiller steering has an issue that I believe is resolvable (found someone on this board who went thru this issue - see http://list.sailnet.net/read/messages?id=247108)... Deck around the mast step is slightly depressed (not cracked) - probably a little more than a 1/4", if that. Below, the head liner above the compression post is cracked, as is the hull liner near where the compression post is glassed into the keel (the latter is a 3" vertical crack in the hull liner on the small step going into the head). The base of the compression post (oak), where it is glassed into the keel, is damp and a bit soft (maybe the bottom 3/4"). The boat is wet-stored, and otherwise is bone dry. While I would get it repaired right away, I'm not seeing it as a reason to walk (or run..) away, but instead view as something that I'll factor into my offer should I decide to move ahead. (Ultimately, I'll defer to my surveyor.)
Thoughts?
CLucas is online now
post #17 of 24 Old 02-13-2007
Originally Posted by CLucas
......Looking at 2 comparable P30s ....Deck around the mast step is slightly depressed (not cracked) - probably a little more than a 1/4", if that. Below, the head liner above the compression post is cracked, as is the hull liner near where the compression post is glassed into the keel (the latter is a 3" vertical crack in the hull liner on the small step going into the head). The base of the compression post (oak), where it is glassed into the keel, is damp and a bit soft (maybe the bottom 3/4"). The boat is wet-stored, and otherwise is bone dry. While I would get it repaired right away, I'm not seeing it as a reason to walk (or run..) away, but instead view as something that I'll factor into my offer should I decide to move ahead. (Ultimately, I'll defer to my surveyor.)
Thoughts?
Not a good sign to have the bottom of the compression post wet and rotting. My advice would be to get a written repair estimate from a qualified firm (or get the estimates that seller probably already has...) so that if its too large you don't have to walk away from the cost of the survey. My bet would be that the seller is hoping somebody will take this problem off his/her hands...The surveyor is not likely to estimate the cost of a repair.
post #18 of 24 Old 02-13-2007 Thread Starter
CLucas's Avatar
The broker is also the dock master where the boat currently resides -- his facility is 100% sail and he claims to have a guy who can do the work there (I haven't checked him out and wouldn't go that route until I saw some of his work or got references). Other work I would have done before taking ownership includes replacing some of the thru-hulls (it's a 1977 hull and some have gate valves which were standard on some Pearsons -- at least one is corroded) and hoses coming off the thru-hulls. Good idea to get a few estimates before making an offer and paying for a survey. If the broker's guy is any good, I could also make my offer conditional on those items being fully repaired.
post #19 of 24 Old 02-14-2007
The broker is also the dock master.... If the broker's guy is any good, I could also make my offer conditional on those items being fully repaired.
You of couerse need to be sensitive to the fact that the broker has a vested interest in seeing that no obstacles arise relative to the sale of the vessel. You might be wise to bring in an outsider, say from another area yard where you could have the work done, to estimates the repairs. I think any actual repair of a boat structure routinely exceeds the best of estimates (double it is my guideline), but if the yard has its own interest in it, watch out.
If the estimates don't send you elsewhere, then the surveyor can advise on whether the estimates cover the approach he/she recommends.
post #20 of 24 Old 02-14-2007
paulk's Avatar
In their used boat buying guide, Practical Sailor suggests that the Pearson 30 is a good light-air boat. If you plan on weekending in LIS in the summer, that is what you will need. The additional length will also extend your range and so be able to get you to more places. Hitting the same ports every time because the others are "too far" gets old very quickly. If you have growing childen, this is particularly true. The Pearson's cockpit is also big enough to be comfortable, especially if you can lift the tiller up at anchor. CD's have a reputation for solidity, which is great if you've got 25 knot breezes to deal with. That doesn't happen much on LIS, and motoring is getting more expensive all the time.
paulk is offline
Rounding Cape Hatteras John Kretschmer Seamanship Articles 0 04-13-2004 08:00 PM
Rounding Cape Hatteras John Kretschmer Cruising Articles 0 04-13-2004 08:00 PM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
The Cape Cod Canal Joy Smith Cruising Articles 0 06-28-2002 08:00 PM
Cape Horn Charter Opportunities John Kretschmer Cruising Articles 0 03-28-2002 07:00 PM
