your 40-42´ bluewater cruiser - SailNet Community
post #1 of 9 Old 01-10-2002 Thread Starter
Hi everyone,
I am new in this msg board and I am trying to refrase an old question. Putting aside electronics, looking strictly from safety, seaworthiness, and structural design aspects, which is, at the bottom of the (price or quality) scale the used (and how old) 40-42´ boat you would consider boarding to make a bluewater, long passage cruise?
Regards to all,
ldatsailnet is offline
post #2 of 9 Old 01-11-2002
Moderator
Jeff_H's Avatar
If I get your question you are asking,''what is the cheapest used 40-42 foot boat that is suitable to make a bluewater, long passage cruise?
I will start by saying that you can make safe offshore passages in smaller boats and that that you may be able to get a better built, faster, more comfortable smaller boat for less money. The boats in the offshore capable boats in the 40-42 foot range that are at the bottom of the price range tend to be way older and have comparatively small interior volumes.
The other issue is how much work and money it will take to take a beater example of inherently offshore capable boat in the 40-42 foot range and make it offshore capable. The problem with big inexpensive boats is that they have a lot of age on them. Because of thier size, the parts to put one into solid shape are going to be expensive.
As with any ''cheap boat'', a survey is even more critical because there are a lot of problems that can cause boats to be cheaply priced and you are buying an inexpensive boat to save money and so if you get one with big (read expensive) problems then you have''n''t really saved any money. People who buy inexpensive boats often do not have the money to properly maintain them adding to the problem of buying a ''cheap boat''. You can expect to find some ''issues'' with any boat this age. Unless the boat has been very well maintained and updated by a previous owner, you might expect some combination of the following items will need attention:
·Sails, chainplates, standing and running rigging that are beyond their useful lifespan,
·an engine that is in need of rebuild or replacement,
·worn out or out of date deck, galley, and head hardware,
·worn out upholstery,
·electronics that are non operational, or in need of updating,
·electrical and plumbing systems that need repairs, upgrades to modern standards or replacement.
·Blister, fatigue, hull deck joint or deck coring problems
·Keel bolt replacement (bolt on keel) or delamination of the hull from the ballast for a glassed in keel.
·And perhaps a whole range of aesthetic issues.
So while you may be able to buy some big boats cheaply, you may end up with a lot more in them than it would appear at first blush. Because there is a real limit to what you can sell these older boats for that is often less than it takes to fix one up, in the long run you may be better off buying one that someone else has prepared to go offshore and save a lot of pain and heartache along the way.
Tartan 41- (high $30K- high $40K range)
Probably at the top of my list would be the 1970''s era Tartan 41. I raced on T41''s in the 1970''s. These were pretty hard boats to sail as race boats but they were well made and pretty fast and if you were not pushing them hard were good boats. There were a number of interiors fitted in these boats. Some were stripped out racers but most had a very workable cruising interior.
Other choices might include:
Cal 40
These are really neat old boats. They sell in a wide range of pricing depending on their condition. They are very fast boats for their day and offered a good workable interior. They were lightly built for the technology of the day and so a beater may need to serious work done it it.
Chris Craft Commanche- 42 feet (typically $39K to $50K)
These were nicely detailed S&S designs. As I recall from 25 or more years ago, they had simple well thought out interiors and sailed quite well.
Condor 40-
These are really neat Trimarrans. They were designed for short handed offshore work and really good at that kind of thing. Thier shoal draft lets them get into backwaters that a monohull this size can only dream of.
Ericson 41;
There were two extremely different boats called the Ericson 41. The 1960''s era boat is a visually beautiful boat that would be a neat boat to own even if they are pretty slow and wet. The later 1970''s boat offers a lot of room and a very interesting boat. It would not be very high on my list to go offshore but would not fall at the bottom either.
Hughes Northstar 40,
These boats are listed under a lot of different names. They came in a lot of different versions as well. These are good boats often over looked in the market place. I have seen them as cheaply as $50K but most seem to ask more than that.
Islander 41:
Islander built two 41 footers. The 1960''s boat ($30- 40K range) was a visually beautiful boat that would be at the bottom threshold of a boat I would go offshore on. The more modern Doug Peterson design would not make a good offshore cruiser.
Kalik 40
Nicely finished performance cruisers. They had teak decks which could be a real problem by now.
Little Harbor one ton. (42 feet)
These were heavy duty boats intended as offshore race boats but built in a day when racers could go cruising. These are very solid boats. They do have a strange interior. They were all originally centerboard boats but over time some have been converted to fin keels.
OLD early 1970''s era IOR race boats...
This is a real mixed bag. These boats can vary from some real junk to some very solid well engineered boats. Some have been refitted as cruisers. Some are stripped out down below and provide a platform to design and build a reasonable cruising interior.
Pearson Rhodes 41, Bounty II, and Cheoy Lee Rhodes Reliant (Offshore 41):
These are very similar Rhodes designed boats. The Bounty and Bounty used the same molds and the Offshore and Reliant were essentially the same boat and had a neat but strange layout. These are truely venerable old girls. While they are wet and very slow when compared to more modern designs they are still very good boats for what they are.
Whitby 42 (start in the mid $50k range)
Venerable offshore boats. Not fast, but good boats for what they are.
I am out of time here but this should give you a good start.
Good luck,
Jeff_H is offline
The Following User Says Thank You to Jeff_H For This Useful Post:
Steady Hand (06-17-2014)
post #3 of 9 Old 01-14-2002
Jeff,
You didn''t mention old Morgans in your reply. Any knowledge or opinion of them as bluewater cruisers?
KathieO
kosullivan is offline
post #4 of 9 Old 01-14-2002
Moderator
Jeff_H's Avatar
I know I will catch some heat here from the local chapter of I love my Morgan, but I at best I think of old Morgans as being good liveaboards and OK down island boats but to me, most of them are by no stretch my idea of a ''blue water cruiser. In my opinion the two closest models are the 43 and 45 but these are bigger than the range requested in the original post. Yes I know a lot of folks have done all kinds of wonderful things with old Morgans. I am thrilled for them and delighted that they were able to do what they did. It still does not make an old Morgan a blue water boat in my book.
Jeff_H is offline
post #5 of 9 Old 01-14-2002
I tend to agree with you on the blue water aspects of the old morgan''s,however; several
of them have gone all the way around.Which
proves the point I always make.It is not what''s under your feet that counts but how you use it and the old noggin!!!
manateee_gene is offline
post #6 of 9 Old 01-18-2002 Thread Starter
Thanks, Jeff
Although new to this msg board, I noticed and I appreciate your thought-out, thorough replies.
This was the kind of information I was expecting. I was reading the excellent Nigel Calder´s book on cruising which provides a lot of good recommendations about the essential features for a good cruising boat, and weak spots of existing ones. One path mentioned is to get a cheap but reliable structure and retrofit thouroughly.
Regards,
Lycio
post #7 of 9 Old 01-31-2002
Please go to the " www.a1line.com ".You will find so many good opportunities for you.
Thanks.
a1line is offline
post #8 of 9 Old 02-01-2002
Moderator
Jeff_H's Avatar
Why would any one go to " www.a1line.com " when your obvious total lack of ethics as evidenced by spamming this forum and violating its rules against commercial posting shows that you are a totally untrustworthy person?
Jeff_H is offline
post #9 of 9 Old 02-28-2002
I have a 1981 Bristol 41.1 for sale if you are interested. The 41.1 is a Ted Hood design centercockpit/centerboard. The vessel has a well established reputation.
lashe is offline
Coastal or Bluewater... hrmacdonald2000 Boat Review and Purchase Forum 10 03-06-2013 01:58 AM
Bluewater defined? dch Learning to Sail 44 07-29-2009 08:20 PM
Pearson 323 - suitable bluewater cruiser?? michaeledelson Cruising & Liveaboard Forum 4 11-21-2006 11:53 PM
cruiser vs live-a-board tybeefolk Boat Review and Purchase Forum 13 02-04-2004 02:41 AM
inland water pocket cruiser dzg747 Boat Review and Purchase Forum 4 02-27-2002 01:36 PM
