First Boat-31' Southern Cross or 27' Hunter - Page 2 - SailNet Community
post #11 of 52 Old 03-16-2007
Here .. Pull this
A 31 foot sailboat in good condition costs a minimum of $50,000.00 You can pay it several ways..all upfront when you buy a boat in decent condition, half and half buying something that is okay but needs work, or nothing at the front end and spending the other $47,500.00 over the following twelve months. But sooner or later - you are going to spend it. So if you don't have 50K to spend over the next twelve months, you can't afford the Southern Cross.
Also, I am honestly not trying to offend you, but if you are at a level of experience where you are not aware of the differences between the Hunter anad the Southern Cross, then you are not ready for one.
There is a lavyer of balsa between the inner and outer fibreglass skins of the boat. If it is cheap, it is likely that there is a problem there, and unless you've beeen working on boats for a while, you don't have the expertise to repair it properly.
Get the Hunter - have a great time, learn to sail and run aground a few times. If you maintain it and even upgrade it a little you will always be able to sell it for what you paid for it.
Sailormann is offline
post #12 of 52 Old 03-16-2007 Thread Starter
The Hunter is 1984, cabin, deck and hull pretty good shape but does need bottom job. Also needs front hatch. Has running Renault 8 Hp deisel and comes with 3 sails. Can pick up for $1500.00, can probably pick up SC around same price but you're right, alot of time and money.
gentryd is offline
post #13 of 52 Old 03-16-2007
The SC31 must be in really rotten shape. Ones in good condition list for about $30,000, and sell for probably about $22-26,000, depending on their condition and what equipment is on them.
A mid-1980s Hunter is probably a boat I'd want to avoid. That was the time period that had gained Hunter much of its reputation for making really flimsy and shoddy boats. Getting a keelboat that is longer than 26' for less than $10,000 is generally going to be a boat in pretty bad shape, that either needs a lot of work or has serious structural issues.
sailingdog is offline
post #14 of 52 Old 03-16-2007
Valiente's Avatar
Talking
A friend of mine got a late '70s Pearson 30 in good shape for $10K last season and shipped it from Conn. to Toronto. He's got fresh sails and a few odds and ends, put in a new head (the wife was squeamish) and spent about $3000 in total getting it right.
So it *can* be done...but you've got to be really picky. As his last boat was a late '60s 24 foot Shark, he's over the moon with all that wide open space and 5' 10" headroom
Valiente is offline
post #15 of 52 Old 03-16-2007
It happens, but not too commonly...and this guy is looking at $1500 if I read his post right... when was the last time you saw a 27'+ boat that was in decent shape for less than $10,000???
post #16 of 52 Old 03-16-2007 Thread Starter
$1500.00 is read right, basically paying past due slip fees, guy just wants out of it. My inquiry was on SC boats as there's not alot out there, Said I was new to sailing, not to boating. Been on saltwater boats all my life and have totally redone 2 fiberglass boats. Don't know sailboats, but do know boats. Thought I'd square that up as some responses lead to the perception that I'm ignorant to boating altogether. I do appreciate all the responses, they have been most helpful
gentryd is offline
post #17 of 52 Old 03-16-2007
Here .. Pull this
Ahhhh - so if you're not a boating newbie then we don't have to be qute so nice to you We try to be on our best behaviour with total landlubbers
...anyway...a Southern Cross has a cored hull, which is a bad, bad thing in a neglected boat. They were sold (mostly as unfinished shells) to people who wanted Valiants but couldn't afford them.
Because they were owner-finished inside, you are almost guaranteed that there are holes through the skin and into the core, and that the core is wet - hence rotten in places. Besides, they are fat, slow and ugly and sometimes the kindest thing to do to a boat is just let it sink as nature intended...
post #18 of 52 Old 03-16-2007
Sailormann-
The coring in the hull of the Southern Cross boats isn't balsa, IIRC, it is cored with Airex, which was IIRC a PVC-based foam. I believe the decks were cored with end-grain balsa, rather than the Airex material.
Also, many of the Southern Crosses may have been owner finished, but some were factory finished.
They may be slow, but they're very solid boats, if they were properly maintained, and are reasonably priced for a bluewater capable boat. Pat Henry circumnavigated in her SC31, and Donna Lange is about to finish a circumnavigation in an SC28. Not too many other boats can compete for the price, size and value.
One major advantage the Southern Cross has as a cruising boat is that the cabin temperature tends to be a bit easier to control thanks to the cored hull and deck. Also, it tends not to have the condensation problems in cooler weather than a solid fiberglass boat will have.
The Elizabethan 31 and the Hallberg-Rassy Monsun are two others that are about the same size and value, and with about the same capabilities.
post #19 of 52 Old 03-16-2007 Thread Starter
Does anybody know if there's a way to find out if the hull was factory finished or kit by the hull #. I'm really thinking now I should get them both. Dry dock the SC for a couple of years and take my time with her, and learn the sailing ropes on the Hunter until I finish the SC
gentryd is offline
post #20 of 52 Old 03-16-2007
'87 Pearson 27'
jackytdunaway's Avatar
I''m sort of a newbie but for the money if you can't make up your mind and have the room get them both. Sail the Hunter while you spet the next few years tinkering with the SC. Just don't try to make them both bristol. spend the money and time on the SC and wear what liitle there is of the hunter out while you sail it. But like i said i am a newbie
P-27
jackytdunaway is offline
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 08:00 PM
Preparing Your Boat for Winter Bruce Caldwell Gear and Maintenance Articles 0 11-03-2002 08:00 PM
The New Racing Rules Dobbs Davis Racing Articles 0 04-04-2001 09:00 PM
Replacing Our Boat Sue & Larry Buying a Boat Articles 0 07-31-1999 09:00 PM
How to Choose the Right Boat Don Casey Cruising Articles 0 04-20-1999 09:00 PM
