- Quick Menu
04-04-2007
mast height 37'
what is the height of the mast above the waterline, on a rerular sloop, wht is the total height from keel to top?does anyone know any good AFFORDABLE perkins wrenches in the D.C./ Baltimore area?
04-04-2007
Wandering Aimlessly
Mast height, varies by boat, and even model of the same boat. Also, are you wondering about mast height, or bridge clearance?
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Website & Blog
04-04-2007
The height of the mast above the waterline depends on the boat, since different boats have different amounts of freeboard and different cabin heights.
Same thing for the distance between the bottom of the keel to the top of the cabin top.
04-04-2007
Newbie
Dude....we need more info about your "regular sloop". Like maybe; what make , what model, what year etc.
04-04-2007
Once questioned about what should be the lenght of a mans legs, Abraham Linclon answered:
From his hips to the ground!!!
Does that answer your question???
04-04-2007
You can use this link to get your rig dimmensions.
Sailboat Rig Dimensions
That will give you the (I)
Than all you need to know is your freeboard and you can determine your bridge clearence or overall height.
04-04-2007
Sailortjk1-
Freeboard is generally the height from the waterline to the deck, but generally doesn't include the doghouse's height above the deck, so you'd be a bit short on that measurement unless the boat is a flush deck design, which most cruising boats aren't. Also, you need to add some distance for the VHF antenna, masthead lights and windex.
04-04-2007
Jesus Dog, you think the extra antanna is gonna make that much difference. This guy doesn't even know where to start.
"I" does not include the deckhouse.
From the link..........
" I" is measured along the front of mast from the genoa halyard to the main deck. The main deck is where the deck would be if there were no deckhouse.
04-04-2007
LOL, true, he's pretty far from a clue...
BTW, you're right about the "I" including the deckhouse, but only gives the mast and doghouse height if the boat is a masthead rig. However, IIRC, if it is a fractional rig, then "I" doesn't go to the top of the mast. So we really need to know what the boat is...
04-04-2007
I surrender, correct.
Therelic, is your boat Fractional or Masthead rigged?
Do you know? Do you know the difference?
| Thread Tools |
Search this Thread |
