Blogs
User Name
Old 01-30-2002
troyaux troyaux is offline
troyaux is on a distinguished road
is the Carribean coastal sailing or offshore?
I have been looking at boats to sail the carribean and across the gulf from the keys to mexico .....would I be happier in the roominess of a coastal cruiser or would it be unsafe to cross the gulf in a 30 year old coastal cruiser such as an O Day, Hunter, Irwin, ect... Before you reply....i cannot afford a Sabre, Tartan, Pearson from the ads i have seen, Please help me get a good perspective on this??
Old 02-02-2002
gto2 gto2 is offline
gto2 is on a distinguished road
although any of the boats you mention can and have made those voyages under the right conditions, none are considered offshore boats. what price / size range are you attempting to stay within? if you can''t see land, you are offshore!
Old 02-03-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enoughJeff_H will become famous soon enough
I think that too much is made of these terms offshore or coastal cruisers. While there can be major distictions between how a specific boat is intended to be used, when you talk about extended cruising in areas that are somewhat breezy in nature, then you are better off in a boat that has certain kinds of attributes, (such as robust construction, good deck hardware, good sails and reefing gear, seaberths, plenty of storage and tankage, small but operable portlights, and a comparatively small cockpit with large drains.)
If you are an experienced sailor with good boat repairing skills, you can by with a boat that compromises on some of these characteristics and can upgrade the boat to over come any serious deficiencies.
When you talk about the Carribean you are talking about a large region with a wide varieties of sailing conditions. Areas like the Vigin Islands offer a wide range of marine services within a day or so sail of anywhere. The conditions are quite breezy but rarely more than manageable and when things get dicey there are plenty of places to duck in and wait things out. Other areas of the Carribean you are several days away from safe ports of refuge and conditions can be less predictable.
People have cruised these areas in allkinds of boats. It can be done with some skill and some luck. That said, this all comes down to risk management. How much are you willing to risk? If you end up buying an unsuitable boat, the chances are greater that something catastrophic will happen. You are clearly on a tight budget. That catastrophy may not be that you sink your boat or loose your rig. It may simply be that you loose some part of the boat that you cannot fix with spares onboard in some remote corner of the world and cannot affort to buy the part and have it shipped to where you are and are forced to leave your boat in a hurricane zone and return to the States to refresh the kitty. While this can happen on any boat, it is less like to happen on a more robustly constructed boat and one designed for the kind of proplonged exposure to the kind of conditions encountered in these breezier corners of the world.
Given your budget, probably the best way to go may be to buy an older, tougher boat from the 1960''s or early 1970''s that someone has spent time restoring, and then spend some more time going over the boat and carefully upgrading those few items that might have been missed by the previous owner.
Sponsored Ad
Old 02-04-2002
thomas s thomas s is offline
thomas s is on a distinguished road
Jeff, are you feeling alright. Your not supposed to recommend older boats!
thomas
Old 02-04-2002
BigRed56 BigRed56 is offline
BigRed56 is on a distinguished road
Ahoy Jeff , hey I ain''t no doctor but you better take a shot of anti- humility and lie down. Call me in the morning if your visions of money plums and "J''s"aren''t back in yer head. Just kidding,now your right snd ye be deserving of your own command by me thinking. Big Red the Pirate of Pine Island.
Old 02-05-2002
Jeff, I appreciate your sincerity and wealth of knowledge. I will be sailing sw Florida and the Keys with trips to the Bahamas and also my local area is very shallow.... I was wondering if you could recommend some shoal draft or center board or swing keel boats that you''d consider well enough built to handle that trip around the Carribean. I do have a budget of under 20-25,000 so I had been looking at production boats such as the O day''s and such. What models in the 29-31 foot range can you recommend? I know older boats were built heavier but does that also mean that its still stronger considering age and the pounding that its taken? I hear some folks here talk about how a production boat made in the 80''s doesn''t need to be as heavy as it is better enginered. I am unsure of which direction to head toward.??????
Old 02-05-2002
manateee_gene manateee_gene is offline
manateee_gene is on a distinguished road
Try looking at the Lats and Atts.b.b.There is
a fully equipped 28''er that just came back from a few months out in islands for under 10K
Old 02-05-2002
rbh1515 rbh1515 is offline
rbh1515 is on a distinguished road
On your budget I would recommend a Morgan Out Island 33 that has been well mentained. It has a shoal draft, and has alot of room. It is very heavy (14,000#) and IMHO was pretty well made. You can get one between $20 and $30k. I know Jeff will scoff at this suggestion, but oh well! I would recommend one made after 1975. Rob
Old 02-05-2002
O.K. I just checked the Lats.and Atts. B.B.
A fellow by the name of Robbie has a Irwin 28 for sail fully equipped,located in NoName Harbor in the Keys.Claims its in perfect cruise ready condition claims to have just returned from the Islands.$3k stripped,$5k fully loaded!He is not on the weg.ph# 571-236-7912.
GOOD LUCK!!!
Old 02-05-2002
Jeff_H's Avatar
Super Moderator
I think there are a lot of good boats in the 20 to 25K range. I agree that many of the early fiberglass boats were quite heavy without being especially sturdy. The 1970''s was in some ways the sorst period because boats were getting lighter but engineering had not improved. By the 1980''s there was a better materials and methods as well as a better understanding of designing fiberglass structures.
Probably my favorite is the Tartan 30 from the 1970''s. These are nicely designed and reasonably constructed boats. I have posted this list before but here is my list of favorites under 25 K.
-Albin Ballad (30 feet (1973-1978) $12-20K)
These are reasonably fast and very well built and finished boats. They are not especially roomy but are good boats for short handing. They are beautiful looking boats. Most have a Volvo 10 hp diesel.
Albin Cumulus (28 feet-(early 1980''s) $15-18K)
These fractional rigged sloops would be a ideal first boat. They are reasonably fast and easy to handle. They are nicely finished and typically have diesels. The interiors on these boats are not exactly plush but is reasonable.
Alberg 30: slow, wet but rugged and cheap to buy.
Beneteau First 30 or 30E (30 feet (early 1980''s) $18-22K)
Fairly modern design that should sail reasonably well. Not the most solid boats but fine for Florida and the Bahamas. They had diesels and pretty good hardware. The 30E might be a fractional rig, I don''t recall.
-C&C Corvette (31 feet (1967- 1970) $15-22K) and -C&C Redwing (30 footer ( 1965-1970) $12K- 20K)
Attractive and reasonably venerable designs; they are not especially fast but OK for the era. The Corvettes are moderately long keel/ centerboard boats and so are great for poking around the shallower areas of the Bay. The Redwings are fin keel/spade rudder boats and in many ways are less suitable for what you want to so than the Corvette.
Cal 2-30 and Cal 2-29''s (just under 30 feet (mid 1960-early 1970''s) $10-18K)
These are reasonably built racer cruisers that have reasonable accommodations and pretty fair sailing ability. Like the Cal 25, the design is a dated and if the gear has not been updated will be less convenient than a more modern design But these boats have gone a lot of places.
Dehler 31 (31 feet (Mid to late 1980''s) under $20K to mid-20K range)
These are really neat little boats. They are reasonably fast and look easy to sail and single-hand. They are fractional rigged and have a very nice interior plan. They would one of my favorites on this list.
Dufour 2800 (28 feet (mid 1980''s) mid $20K)
These are OK boats with a big following. They are not my favorite but they would not be a bad boat if the price were right.
Irwin Competition 30 (30 feet(mid 1970''s) $12-16K)
These were well rounded little boats that sailed well and had reasonably nice interiors. There was one that dominated its class in PHRF for years. Irwin''s were not the most solidly built boats and so you are looking for a well maintained example in reasonably good shape. You may have some serious beefing up to do if you plan to do the Carribean.
MG27 (27 foot (Mid 1980''s) under $20K)
Nice little fractional rigged English boats. They seem to be well mannered and have an interior layout similar to my now sold Laser 28. They have a diesel aux. But tiny tanks that will need to get upgraded.
1970''s vintage Tartan 30''s, (30 feet( 1970''s) under $20K)
These are my favorite masthead sloops of that era. They are good all around boats. Most still atomic 4''s but you can find them with diesels.
Late 70''s/ early 80''s Hunter 30''s, (30feet (15-20K)
These are very under appreciated boats. We have had two in my family and again it is a matter of finding one that has been upgraded and is in good clean shape. My Dad raced his in PHRF and went for a couple years without finishing lower than a first or second. They are roomy and surprisingly fast.
70''s vintage Pearson 30''s (Not Flyers)
These are very venerable racer/cruisers. Of course they come in all kinds of condition from really well maintained and up graded with good racing hardware and a diesel engine to stripped and trashed. You can buy them from under $10K (but you would not want any in that price range) to something approaching $20K. You should find good boats in the high teens.
Pearson Vanguard, Triton, Wanderer and Coaster: Pretty classic old boats from the 1960''s. They were simple, heavily built and pretty cheap to buy. They are a mixed bag in that their original hardware is bound to be dated and pretty worn out. They are slow, wet and don''t have the most comfortable motions in a chop, but lots of these boats have gone to far away places. Again you really want one that has been maintained and upgraded.
Ranger 29 (29 (early 1970''s) 10-18K)
These are good sailing and nice cruising little boats. They were not the best built boats and so you should be looking for a clean and updated version. Still they offer a lot of bang for the buck.
Wylie 28 and Wylie 30 (28 and 30 respectively(late 1970''s to early 1980''s) 10-15K) These are neat little boats that sail well and are really pretty interesting. The few that I have seen have good hardware and have had simple but workable interiors. They came in fractional and masthead rig versions. There was a masthead version that did quite well on the Bay.
vB code is On
Bluewater defined? dch Learning to Sail 44 07-29-2009 08:20 PM
Dream of Sailing as a living oceanguy Cruising & Liveaboard Forum 20 11-11-2007 11:19 PM
what determines a coastal cruiser??? troyaux Boat Review and Purchase Forum 18 02-15-2007 12:39 AM
A GUIDE TO OFFSHORE PASSAGE MAKERS (Sailing Vessels) piclarke Crew Wanted 0 05-13-2003 05:43 PM
Anyone used Colgate''s Offshore Sailing School in Captiva? DuaneIsing Learning to Sail 11 03-28-2002 02:33 AM
Page generated in 0.9248 seconds (63.22% PHP - 36.78% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
