buying a 60'' steel - Page 2 - SailNet Community
post #11 of 25 Old 02-14-2002
buying a 60'''' steel
First:I said with no DISRESPECT INTENDED !!!!
GOT THAT??? Next I was addressing Bobola,unless that''s you nom-de-plum BUGG OFF!!
manateee_gene is offline
post #12 of 25 Old 02-14-2002
Ahoy, dancy: "No disrespect intended" is a qualification. It preceeds, normally, a criticism, or a disparaging comment. Otherwise, there would be no need for the preemptory. I ask you, has anyone ask you for your credentials? Has anyone qualified your writing here relative to its serious value? Have you submitted your credentials? If not, what right do you have to his credentials? Where is his burden to proof himself? I wrote that in an attempt to preempt the same comment from you to me since I wrote more than he. I was afraid you might also call me to task. I see with your, "Bug off!", that I was unsucessful. This is a casual, open forum where sailors talk. It is not an examination room.
dhartdallas is offline
post #13 of 25 Old 02-18-2002
Dancy8888,
I have owned a 35'' steel sailboat and am now helping a friend totally rebuild a 39'' steel sailboat.
As for my background I was a marine engineer and worked on a number of metal and fiberglass sail and power boats throughout the Caribbean and all over the East coast. My comments are based on my first hand experience as an engineer, a steel boat owner, and my recent experience with my friend''s corten steel boat.
He had the entire hull sandblasted inside and out (last month) and some parts didn''t get epoxied for 2 weeks, and the metal had virtually no rust!!!! Corten is amazing stuff!
One problem with my boat was that it had exterior wood all over the place. It had a teak cap rail bolted to a raised bulwark. It was a nightmare because of the moisture that infiltrating the space between the wood and the steel it sat on. I''m sure the original owner laid down lots of good paint on the steel, and probably a good thick coat of 5200 on the underside of the wood, but eventually the moisture gets in. Exterior wood on a steel boat is a huge mistake if it''s bolted down!!!
The other problem was that there were larger sections of the interior bilge that were impossible to access, without tearing out the ''permanent'' flooring. There was rust in one area under the head that I could just barely reach, but could feel it with my fingertips. And I have long arms – I’m 6’7”. A shorter person might not have known it was there. Rather than tear up beautiful old woodwork, I covered the metal best I could with coal tar epoxy, after getting as much of the rust out as I could.
On my friends boat all the wood handrails have been replaced with curved stainless piping welded to the hull. Same with the stantion bases - welded to the hull. No holes to leak. The sum of all the exterior wood will be the seats and flooring in the cockpit. The sum of the holes in the hull are the minimum necessary. I''m even looking into the possibility of replacing the 2 pipes used for draining the cockpit with bigger pipe and using one as the main intake and the other as the main discharge. Both pipes are on either side of the keel so there shouldn’t be a problem of the discharge water getting into the intake pipe as long as the bow is kept into a current flow. At a dock this might not work. The big problem I see with this is keeping discharge fumes out of the cockpit, and dirt from the cockpit fouling the intake screen. The fewer holes, the better.
Wiring is another very important consideration. We’ll use an isolation transformer for the shore power and ground everything via one connection at the engine.
The interior floor will be easily removable for inspecting the whole bilge area. We even plan to make the furniture in sections and easy to unbolt from the stringers for complete access to any area of the hull that might need attention. As on my boat there are absolutely no limber holes to be found. The time to build them in is when you are making the stringers, not after the hull has been built. Drilling them now would be a huge project. The other option is to make the boat as water tight as possible, which is what we are doing with this boat.
The guy who built my boat did a wonderful job, but he made it a maintenance nightmare.
Steel boats will last a long time - they just have to be built, wired and maintained the right way so that they don’t become sailing ‘fizzies’.
Bobola is offline
post #14 of 25 Old 02-18-2002
Thank you for your imput!I think its incumbent upon all of us giving advice on the various boards;to speak from actual experience!not from what we have read that has been written by others!Good Luck on the project!
post #15 of 25 Old 02-18-2002
8888 ,what is your e-mail?
thomas
thomasrstone@hotmail.com
thomas s is offline
post #16 of 25 Old 02-18-2002
Wow, Dancy8888, you are so full of sh#t.
Here is one of your postings answering someones question about when leave the west coast..
"If you could use the traditional weather plotting charts it would be simple;however,another El Nino is rearing its head out in the Pacific and the weather is not what its supposed to be!We are starting down the slippery slope of CHANGE
make no plans take it as it comes be prepared
for ANYTHING!!!!! "
DO YOU HAVE A PHD IN METEOROLOGY, OR DID YOU READ THAT SOMEWHERE? I''M SURE THE POSTER IS ETERNALLY GREATFUL FOR YOU KEEN SENSE FOR THE OBVIOUS.
aasault is offline
post #17 of 25 Old 02-18-2002
assualt, you are a little late on this one. I have first dibs on whatever charts 88 has.
thomas
thomas s is offline
post #18 of 25 Old 02-19-2002
dancy8888,
Thanks. Yea, nothing like first hand experience. I plan to build a web site devoted to the history of the boat and to the reconstruction of it as well. Will let you know when it''s available.
Bobola is offline
post #19 of 25 Old 02-19-2002
Well:Mr.A.H. go to Ocean Conveyer Belt on your search engine and follow the threads.
I was in Baja Mexico last El Nino I saw first hand how un reliable the Pilot Charts were at that time.!!Bug Out!!
post #20 of 25 Old 02-19-2002
thomas:do your own search!~Look at the websites dealing with weather and ocean currents.Read what learned men are saying.I was actually at sea last El Nino I saw how screwed up the weather predictions were as opposed to the on site actuals!
Weather is something you study your whole cruising life.The sum total of your own knowledge and EXPERIENCE is what you use to evulate your on site weather!!HELL!! when we were 1500 miles offshore fishing Albacore the weather reports were useless we saw the weather before the predictors!!!
Steel vs Fiberglass me262 Boat Review and Purchase Forum 24 08-28-2015 09:11 AM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 04:46 PM
Steel Boat jmaine Boat Review and Purchase Forum 1 04-05-2003 11:58 AM
Spade Anchors Aluminum vs Steel thomsonjd Gear & Maintenance 1 12-31-2001 01:54 PM
Welcome to Buying a Boat messageboard Boat Review and Purchase Forum 1 09-14-2000 05:22 PM
