06-01-2007
Here .. Pull this
Other than the pull line, cleat and pivot point, what can do wrong?
Not a lot. You might find sea creatures setting up housekeeping inside the trunk, thus making it difficult to raise it completely, or might scrape the sides of it when you raise and lower it. If you run aground, it might bend (depending on how it is constructed) but it is more likely that your pivot will be damaged than the keel itself ...
The primary thing to look at is how it is constructed, and whether or not it is sound. If it is a flat piece of metal encased in fibreglass, or something else, it's possible that there may be some internal corrosion if the outer sheathing has been damaged. I have no knowledge of O'Day swing keels, so I think that the best thing to do would be to ask for information regarding the constuction on the O'Day Owner's website. Would probably be a good idea to hang out on there for a while to see what problems tend to occur with that particular model.
Hope it works out well for you
