Wet deck... - SailNet Community
Blogs
Old 05-27-2007
Everlong is on a distinguished road
Wet deck...
What exactly is a wet deck ???
Old 05-27-2007
camaraderie's Avatar
moderate?
Decks on sailboats are usually made of a sandwich of 2 layers of Fibeglass with a core in between them. These days the core is often foam, but in older boats it was often marine plywood or balsa. If moisture gets down into this core it tends to spread and rot the wood causing delamination, leaks and s loss of structural strength...all bad things. Extensive "wet decks" can be a major pain and expense to repair.
Old 05-27-2007
Everlong, ignore Cam....that's not a wet deck, that's a screwd up deck....
this is a wet deck....
Old 05-27-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
giu, no toe rail ?
S/V Scheherazade
Old 05-27-2007
Originally Posted by Freesail99
giu, no toe rail ?
Nope...I ran out of money!!!
Old 05-27-2007
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Nice boat Giu.
A wet deck is when you are sailing and you have green water flowing across your deck. Not quite a submarine... A lesser interpetation is when a lot of sea spray is crossing your decks.
Sailing with your beam ends (toe rail) awash will give you a wet deck. Have done this on schooners and brigatines, makes for interesting sailing.
Old 05-27-2007
i guess thats where you got all the posts?
Thanks Camaraderie
Old 05-27-2007
Originally Posted by Boasun
Nice boat Giu.
Like this????
Old 05-27-2007
Would mold on the picture be possibly from wet decks?
Old 05-27-2007
here is a better picture
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 08:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
