06-22-2007
Best Looking Moderator
The possible quick fix is a product through West Marine that is an injection into the core. I will not get technical because I have not done it. My understanding from those that have done it is that it is "ok"... and that it will work for small areas.
If the deck is spogy in a larger area, that may not be suitable. Some manufactureres would seciotn of the balsa core, which would restrict any moisture ingress. These are the easier fixes becuase you can cut out and replace just that area. However, that method seemed to be more expensive and many of the production vessels do not follow that. In turn, the moisture can spread further. THis is a more extensive fix and can be pricey.
Any way it goes, outside of a small area that can be injected, you are going to get into some serious work. We were going to buy a Krogen sevreal years ago but the survey came back with spongy decks. It was not a real large area, but given our destinations, would ned to be fixed. THe cost was right around $25,000... and it could exceed that. We walked away from the deal.
I am not an expert in this area so please take my comments as such. I would also agree with the poster above that stated you may spend more fixing up a good deal than if you had spent more up front for a tub in better condition.
Take care.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
