Just bought my first boat! Catalina 27 diesel - Page 2 - SailNet Community
post #11 of 17 Old 07-01-2007
Older Junior Member
lsusailing's Avatar
Suggestion only. If the fuel tank is loose and you think it is easy to remove, remove it and clean it out. This is an old boat so you do not know what is inside the tank. You will probably find the fuel gauge system gunked up and gump at the bottom of the tank. If so, clean it out. Put a small chain in and pour a little diesel or kerosene and keep on moving it around and draining until it is clean, reinstall. This is the best thing you can do, along with changing the fuel filters. This will make sure that you boat "will go"
$2k is fine, makes up for any issues you have.....
LSU Sailing
s/v Daphne
lsusailing is offline
post #12 of 17 Old 07-01-2007
The spreaders themselves on the older Catalina 27s and 30s were made of wood, and definitely need to be replaced. I've seen a lot of older Catalinas lately, and a fair number of them have the originals. The aluminum replacement is something like $350. Check the chainplates while you're at it. I know that up until 1978 the chainplates on the 30s had to be retrofitted.
sailhog is offline
post #13 of 17 Old 07-02-2007 Thread Starter
The spreaders are not wood, they are aluminum (not sure if they were replaced, or are original) - but their brackets are cracked (broken) so I need new ones. Also, I think I will sink new stainless keel-bolts, to help support the original (rusty) bolts.
I think the tank cannot be removed easily, but I might just pump it out and clean it as best I can- I am wondering how the heck I will fiberglass it into place though.
I will replace the pulpit eventually - and add a 2-lifeline pulpit, in place of the ingle life lines there now.
Lots of work to do - will keep you posted.
Phillip
7tiger7 is offline
post #14 of 17 Old 06-06-2009
Hoe to move a sailboat onb a cradle
Do you how to move a sailboat which is on a cradle and get the both up on a flatbed trailer and then how to get them off. Any pictures available would be helpful. The sailboat is a 25' Bristol, full keel 6,000 lbs.
musicmanontheseas is offline
post #15 of 17 Old 06-06-2009
Please start your own thread on this issue... instead of hijacking this one, which is about a different boat entirely. I'd highly recommend you read this POST to help you get the most out of sailnet.
sailingdog is offline
post #16 of 17 Old 06-06-2009
Congratulations are in order, at least until you come to your senses!
An important thing to realize here. You bought her for $2000, but all the parts she will need are priced for the $60,000? boat she would be at today's prices. I paid $6500 for my 1984 Etap 26, and despite a huge effort to stay out of boat stores I have spent at least $15,000 already.
Another issue, was this a one owner boat? One owner boats I am finding are bad news. Instead of being used boats, they are often used up boats. All the stuff you think you can just fix wind up being total replacements.
Good luck,
Gary H. Lucas
GaryHLucas is offline
post #17 of 17 Old 06-08-2009
cap'n chronic
cnc33voodoo's Avatar
I will get dr.emitt brown to time port that message for you right away.
c&c 33 tall rig
cnc33voodoo is offline
help with lifes dream kimby Boat Review and Purchase Forum 37 12-03-2009 12:32 AM
The Name Change Jinx (or not) STARWINDY General Discussion (sailing related) 39 07-17-2007 08:04 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 08:00 PM
Two-Boat Tuning Dean Brenner Racing Articles 0 03-13-2002 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 09:00 PM
