Say you're going to sail around the world... - Page 3 - SailNet Community
post #21 of 31 Old 07-18-2007
Originally Posted by camaraderie
I would much rather go to sea in a Tayana 37 singlehanded than in Donna's SC28. My guess is that if given the choice...she would too. Nothing wrong with a small well designed boat but I would always opt for the biggest well designed one I could handle safely.
I would agree only if I had done the preparation and had spent enough time on the Tayana 37 to know it well....otherwise, I'd rather take a smaller boat I am extremely familiar with and know inside and out, over a larger boat that I am a stranger to.
sailingdog is offline
post #22 of 31 Old 07-18-2007
Seńor Member
TrueBlue's Avatar
I would tend to agree with this - but being "very familiar with" the boat or not, I would not even consider sailing across an ocean in a 28 foot trimaran, over doing so in say . . . a 33 ft Nauticat.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #23 of 31 Old 07-18-2007
LOL... spoken like true MOTORSailor...
post #24 of 31 Old 07-18-2007
Seńor Member
TrueBlue's Avatar
Heh - heh . . . at least it doesn't have training wheels.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #25 of 31 Old 07-18-2007
MysticSkipper's Avatar
Lot of competing considerations here. Living aboard for 5+ years, I want comfort. Sailing around the world means some major crossings and safety and stability are huge factors; that really has to come first. But there are some sidebar arguments to be had about how best to address that. Speed can be a safety feature. A long monohull or a multihull will get you across faster and therefore expose you to less danger. But the multilhull has the worst case scenario of a capsize going against it (yes, I know, very unlikely, but it isn't going to self right if it ever happens) but they are fast enough to run from weather systems. The longer monohull is generally going to be more complex to handle and more expensive to purchase and maintain. I think part of the allure of smaller boats is that they can seem stouter (they certainly have less leverage against their ends) and are potentially easier to self rescue. When I munge it all together, my answer is another vote for a monohull in the 30' neighborhood.
MysticSkipper is offline
post #26 of 31 Old 07-18-2007
A multihull may capsize, but they rarely sink...since the position of ultimate stability for a multihull is capsized... however, the position of ultimate stability for a keelboat is sitting upright at the bottom of the ocean... Most of the time you hear about capsized multihulls and the horror stories because the crew has survived to tell it... how many monohulls sink without a trace and without any survivors???
The speed of a multihull, especially the larger production cats, some of which are fairly poor in terms of sailing abilities, generally isn't significant to outrun a fast moving storm system without significant advance notice. On average, a cruising multihull will only move a bit faster than her monohull counterparts.
post #27 of 31 Old 07-18-2007
Maybe I over generalized here, but most of the records for fast crossings are held by multihulls:
World Speed Sailing Record Council
and the ones that are held by monhulls are at much lower speeds.
Your points about ultimate stability are quite valid, though. Sometimes I wonder if the little boats, like Matt Layden's Paradox:
PARADOX
with positive bouancy and chine runners are a reasonable alternative. They get knocked over pretty easy, but bounce right back up. But they go slow and carry very little and force you to live in a box not much bigger than the one we are trying not to occupy anytime soon.
post #28 of 31 Old 07-18-2007
MysticSkipper-
While the majority of the records are held by multihulls, I seriously doubt that anyone is going to go cruising in one of the record setting beasties.
It is very difficult to mistake these two types of boats, and the performance characteristics are completely different. First photo is of a cruising catamaran, second of Ellen's B&Q record-setting trimaran. Not quite the same thing. The record-setting multihulls are not very comfortable as cruising boats.
PARADOX
post #29 of 31 Old 07-18-2007
MysticSkipper-
But aren't the monohull records also held by boats designed to go as fast as possible? The America's Cup boats don't look especially comfortable. Adding the amenities slows them down also. I keep seeing references, here and elsewhere, to cruising multihulls blowing right by monohulls. Speed is a page one feature on most of the multihill builder sites. I think it is a fair statement to say that a cruising catamaran with roughly the same capacity for people and gear will generally go faster than a monohull. My preference is still monohull, but speed is a point I concede to the mutlihull.
post #30 of 31 Old 07-18-2007
I'm not disputing that most multihulls will have a higher average speed than monohulls of the comparable capacity, and definitely higher speeds than monohulls of comparable LWL.
However, touting it as a way to "outrun" bad weather isn't really realistic IMHO. It will help you avoid some bad weather, but some storm systems crop up quickly enough, move fast enough and are large enough that they can't be avoided, regardless of whether you're in a monohull or a multihull.
Heavy weather sailing sailorfrank Learning to Sail 26 09-10-2013 06:32 PM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 10:54 AM
What is the point of a traveller? dwbecker Learning to Sail 9 09-25-2006 08:35 PM
Headsail Reefing Basics Brian Hancock Gear and Maintenance Articles 0 08-05-2004 08:00 PM
Considering a New Mainsail Brian Hancock Cruising Articles 0 04-29-2004 08:00 PM
