07-11-2007
You might want to contact Sue over at Performance Cruising, as she might have some polar diagrams for the Gemini. There is a website about the gemini 105 that one owner put up that you might find of interest. It is located here. While I've had some experience with the Geminis, I couldn't really say how well they go to windward in a pinch. The polars would really give you all the information you want.
BTW, most cruising catamarans aren't going to get a stellar PHRF rating, since they aren't geared towards speed in general. And many cats do have a pointing issue, but that is generally more the case with the stub keel-no board designs than it is with the daggerboard/centerboard equipped boats. They also can have a problem tacking, due to the excessive windage caused by the high freeboard many cats have. Neither of these criticisms are geared towards the Gemini 105 in particular but are more blanket statements about catamarans in general.
