Old 07-24-2007
arbarnhart's Avatar
arbarnhart is on a distinguished road
trailer sailor towing weight comparison chart?
Anyone seen such a thing anywhere? I found a boat comparison at Shorty Pen's site that gave displacements for a lot of boats and I could kind of guess from there, but his chart only goes up to 20' and most of the boats Iam looking at are 21' or 22'.
Old 07-24-2007
Filmsomething's Avatar
Don't panic
Filmsomething is on a distinguished road
What do you plan towing with and we can name off a few boats that fall under that weight
Old 07-24-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
A good source for net weights:
http://www.nadaguides.com/default.as...3&gc=mr&gtc=mr
Old 07-24-2007
arbarnhart's Avatar
Originally Posted by USCGRET1990 View Post
I keep finding "weight: N/A" in the listings there. EDIT - as I check more, I see it does have most.
I am trying to find a delicate balance. I want to stay under 2000 lbs, but not too much under. The SJ21, on a trailer, is pretty much right at my max and I am trying to check some of the other options.
Old 07-24-2007
SENIOR CHIEF
Works for me. What are you looking at to buy, I'll look it up for ya.
Boats and Personal Watercraft
1980 C & C YACHTS
Monohull Sailboats
C & C 24
Length: 24'
Model Name/Description: C & C 24
Boat Type: Monohull Sailboats
Hull Material: Fiberglass
Beam: 8' 10"
Engine: N/A
Net Weight: 3,200
1977 COLUMBIA YACHT
COLUMBIA YACHT
Monohull Sailboats
COLUMBIA T-23
Length: 23'
Model Name/Description: COLUMBIA T-23
Beam: 7' 11"
Engine: N/A
Net Weight: 2,700
1980 CATALINA YACHTS
CATALINA YACHTS
Monohull Sailboats
CATALINA 22
Length: 22'
Model Name/Description: CATALINA 22
Beam: 7' 8"
Engine: N/A
Net Weight: 2,490
Old 07-24-2007
SENIOR CHIEF
1989 SAN JUAN SAILBOATS
SAN JUAN SAILBOATS
Monohull Sailboats
SAN JUAN 21 STD
Length: 21'
Model Name/Description: SAN JUAN 21 STD
Beam: 7'
Engine: N/A
Net Weight: 1,250
Old 07-24-2007
SENIOR CHIEF
These are light!
2006 HUNTER MARINE
LUHRS MARINE GROUP
Monohull Sailboats
HUNTER 216(*)
Length: 22'
Model Name/Description: HUNTER 216(*)
Hull Material: Plastic/Fiberglass
Beam: 7' 11"
Engine: N/A
Net Weight: 1,350
Old 07-25-2007
arbarnhart's Avatar
1972 VENTURE/MACGREGOR YACHT CORP
VENTURE 21
Monohull Sailboats
Length: 21'
Model Name/Description: VENTURE 21
Beam: N/A
Engine: N/A
Net Weight: N/A
Going to other years didn't help.
I could have sworn there was another I tried, but maybe I am just confused...
Old 07-25-2007
Don't panic
I like my Precision 21, lots of room for that small of a boat. But it comes in around 2500 without a trailer I think.
Time to buy a bigger truck
oh captain my captain
Old 07-25-2007
blt2ski's Avatar
Depending upon the tow rig you have.......trying to stay under the manufactures number while good, does come with a few caveats if you will. The tow ratings are based on pull power only. What also happens, if towing say a boat, which is fairly aerodynamic, you will not need as much HP to motovate you as a rig trying to pull a larger travel trailer with a flat boxy front end! Some rigs have a 4K lbs capaicty when pulling an RV trailer or equal, but a 5K capacity when pulling a boat!
I had a rig I pulleupwards of double the tow rating all the time, daily etc, no issues with said rig! In fact, it had less issues than an equal rig with a higher tow rating! It takes 105 hp to motovate a 15K lb rig down the freeway at 60 mph with 70# of frontal area, this 105 HP can vary as much as 30% higher or lower depending upon the aerodynamics of the rig. Meanwhile a 15K rig with 90# of Frontal area, needs 135 HP to go 60 mph on a level, same HP as a 25K lb rig with 70# of frontal area!
In the end, what are you pulling said trailer with? are you going many miles down the road? or just a few on less than 50 mph roads vs interstate roads at 60-65 mph. Larger trucks, ie MDT and HDT rigs get powered based on application, an OTR rig gets more hp for a given wt and setup vs a local delivery rig will have a lower HP rig, but lower overall gearing, so it can go up and down the steeper grades in citys etc, especially like here in Seattle where I am, with grades approching 20 to even 25% in some alley ways! One main road is 18% with stop lights every city block! That takes low gearing and torque to get you moving, not HP.
Moving up to a rig that is 2500 lbs vs 2000, if that boat is correct for you, may not be as bad as you may think it will be. Just make sure the trailer has brakes of some sort, an dyou will then stop. If you have a rig with more than 125 hp, it will move a 3000 lbs trailer reasonably well. I move upwards of 30K daily with my Navistar dumptruck and a 175 non turbo diesel. I am not the fstest guy in twon, but I do get the job done!
Marty
All About Charts Jim Sexton Seamanship Articles 0 11-28-2004 07:00 PM
All About Charts Jim Sexton Her Sailnet Articles 0 11-28-2004 07:00 PM
