Swing keels over fixed - SailNet Community
post #1 of 3 Old 03-11-2002 Thread Starter
I do most of my sailing in the Tampa Bay where it''s easy to find shallow bottom. I''ve started searching for my second boat and heard more and more about swing keels. Just looking for any wisdow this board can provide.
Mauidan is offline
post #2 of 3 Old 03-11-2002
A keel/centerboard (this is not a swing keel or a centerboard alone design) is a tried and true design. It is found on many high end boats like Hinckley and Alden. It is especially popular on much larger boats, to keep draft limited while providing superior offshore performance.
The K/CB design is one that uses a keel AND a CB. The boat can be sailed on the keel alone with no real detriment in performance. The CB can be lowered for some added stability and windward performance.
Of course there is the added maintenance of having to inspect the cable etc. In general there is no yearly work except to look it over. Cables can last a long while.
Hope this helps.
JohnDrake is offline
post #3 of 3 Old 03-11-2002
Moderator
Jeff_H's Avatar
Swing keels have a number of advantages. They allow comparatively easy loading on a trailer and of course can allow youto slip into shallower venues. They are comapratively inexpensive to build and so often show up on value oriented boats.
Of course as with most things in sailing there is also a downside. Generally swing keels have to be kept light enough that they can be hauled up with a reasonable size winch and so are substantially lighter than a comparable fixed keel. As a result swing keel boats generally have less stability than a fixed keel boat. That significantly hurts heavy air performance and safety. This is an important consideration in Tampa where the thunderstorms appear like magic on the best of sailing days.
This lack of stability is typically partially offset by having less sail area on a swing keel boat. And of course that significantly hurts light air performance relative to a well designed fin keel boat.
The worst problem with a swing keel is that they can slam shut in a knock down (something that I have experienced first hand in the Atlantic off of Savannah) and that generally occurs at just the worst time and can do a lot of damage to the boat.
Still and all, while a swing keel is more of a compromise that I would prefer for my own use, if used as designed, swing keel boats allow access to a lot of shallow venues pretty inexpensively.
Jeff_H is offline
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 03:09 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
