Old 09-02-2007
stinkydog's Avatar
stinkydog is on a distinguished road
28 footer recommendations (Pearson 28-2 equivalents?)
Hi -my first post since a long time and several operating systems ago.
I'm looking for a replacement for my good old classic Columbia 28. With a growing family that requires more space (and leaves less time for the wife to help sail), I've found that I need some improvements. Given the same overall length (28 feet or thereabouts), I'd like to see:
EDIT: forgot to mention, this will be an inland/coastal cruiser. Not a racer (although some performance would be nice). Also, I'd prefer to stay away from the mass-produced Walmart brands such as Catalina, Hunter, etc.
Overall design:
- semi-displacement cruiser
- fin keel
- spade rudder (skeg-mounted would be nice, but severely limits the options)
Accomodations:
- lots of interior room given the overall length of 28'.
- a couple of settees in the main salon - or at least a settee and a dinette.
- shower, enclosed head
- at least somewhat of a nav station
- big v-berth for little kids. aft cabin for adults (or vice-versa). other berths (settees) as needed
- tall (6'3" or so) headroom under main cabin trunk
Rigging:
- mid-boom sheeting/traveller
- factory roller furling headsail (or very common upgrade)
Deck/layout:
- real bow anchor locker (not the old porthole to chain locker located forward of the v-berth)
- swim ladder that is easily deployable for small children. most likely meaning reverse transom (even though it doesn't look nautical)
- decently sized cockpit with bridge deck
- pedestal wheel steering
- double lifelines
Engine/propulsion:
- factory diesel (or replacement).
- prop located directly ahead of the rudder. (In my C-28, the prop emerges from the deadwood above the rudder. It's well protected, but forget about any kind of low-speed maneuvering)
Now, the boat that's caught my eye and meets my requirements so far has been the Pearson 28-2 (1985-1989 models). Only problem: I'm on the West coast, and every P-28 I've seen for sale recently has been on the East or Gulf coasts. And they're all for sale by brokers at around $25-$30k, when the 'book' value is closer to $20k or less.
So, I really like the Pearson 28-2, but I'm open to alternatives. I guess the main reason it has caught my eye, other than equipment/rigging/etc, has been the open layout which seems very favorable sailing short-handed with small children.
Thanks in advance for any suggestions, comments, etc.
Old 09-02-2007
ASA and PSIA Instructor
Cal 28 II
The Cal 2 II is a nice design, with a particularly open and spacious interior, sails very well, rates a little faster than the P28 2 (177 versus 180), but will cost a s much, perhaps more than a Pearson. If you want a nice well-built design, you will need to pay the $$$.
Old 09-02-2007
Bardo's Avatar
Just another stop...
Bardo is on a distinguished road
Bristol 29. great boat, meets almost none of your requirements, but I suspect that few do in that length. Showers, 2 setees, wheel steering, aft cabin. Just doesn't seem likely in that length. However, the B29 is a fantastic sailor, very comfortable and well founded, and can be had for about 15K or so, with room to refit to your specs. Ericson 27 might also look good, and there are more of them on the west coast. The Bristol is an east coast boat too, so probably not many there.
Old 09-02-2007
Originally Posted by stinkydog View Post
Overall design:
- fin keel
Not quite sure what you mean by semi-displacement cruiser. Most cruising sailboats are displacement hulls pure and simple... hence their limitation to hull speed of 1.34 * sqrt (LWL).
Accomodations:
Most boats in the 28' range don't have a shower, much less an enclosed, separate shower. Most will have an enclosed head. Very few, if any, have a true aft cabin.
Rigging:
Deck/layout:
- double lifelines
Not many in this size range have a reverse transom with a swim ladder, and most boats under 30' are tiller steered not wheel steering.
Engine/propulsion:
Generally, having too many specific requirements is going to eliminate all of your choices. Some boats that might be otherwise suitable won't have the shower, or the wheel steering as an example. This is especially the case since you say you don't want to have a Catalina, Beneteau, Hunter, Jeanneau.... which make up a large portion of the small coastal cruising sailboat market.
Old 09-02-2007
sonofasonofasailer456 is on a distinguished road
sounds like a Bayliner to me, shove everything you can into the smallest boat you can, so you can have a 2 story boat that is ugly as sin but you have everything under the sun in it
Old 09-04-2007
Moonfish's Avatar
Cruiser/Lats and Atts TV
Moonfish is on a distinguished road
If you find a boat around 28 feet with even half of the items you mentioned... Let us know! I don't think it exists. I was thinking of my first boat, which was a Newport 28. Very spacious for a 28 footer, with the bulkhead mounted folding dinette table. Good sized v-berth, two settees, and a quarter berth. Enclosed head with shower. I think it only had 6 foot headroom though.
Then I thought of the Nor' Sea 27. A Lyle Hess designed, well built, solid little coastal cruiser. They had at least three versions: standard aft cockpit, a pilothouse, and the one you might be interested in, the aft cabin model. I've never been on one, but they have pretty good reputations.
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Old 03-13-2010
Bruce
Gangfurd is on a distinguished road
The original Cal 28 raised deck, whose rudder and hull design were used to perfect the Cal 40, now a Hall of Fame Classic, is a great boat in its own right.
Check it out:
Cal 28 Sailboat Cal Boats Jensen Marine Cal 28 Bill Lathrop Jack Jensen Good Old Boat
Old 03-13-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
+1 for the Cal 28-2. Nice boat.
Old 05-14-2011
oldibtgdy is on a distinguished road
pearson 28-2
the 1986 (or later) pearson 28-2 provides everything you're looking for. plus, they're incredibly well built, they sail sort of like a pregnant J-24, pretty good for a "standup" cabin and a couple of births, if you want to call them that. it's a two-person weekend coastal cruiser totally single-handable and deceptively fast. sails very well in ghosting conditions and balances nicely on any point of sail. rudder straight ahead, thankyouverymuch, without autopilot.
get the deep-draft version (there were two) --- bill was experimenting with underwater shape for his offshore models. the 28-2 is a very nice, affordable small/big boat. start adding spinnakers and all the other strings we like to pull and you've got a very nice racing platform in phrf competition. heck, with my wife at the helm (a non-sailor) and just me pulling strings, we beat a tartan 37 to the first weather mark in less than 5 knots of air rounding just a few seconds after the first boat, a colgate 26. yes, we went the right direction, but there's no excuse for that. get a 1986 or later pearson 28-2 and forget it. they're great boats at a great price. that's why there kind of rare on the market.
in my opinion, the pearson 28-2 beats the heck out of it's columbia/cal counterpart.
Old 05-14-2011
Mobnets is on a distinguished road
A shower in the head is going to be your biggest limiting factor and in my opinion you shouldn't let it be. If you find a boat this size with one it will likely be a handheld and not in a separate enclosure and it will be a hassle. Whole head gets wet . . . shower sump adds maintenance headaches and sometime odors, etc. Humidity issues also. My 32 footer doesn't have a shower in the head (although it was an option and installed in some) and I'm glad. I have a dry, odor-free boat and head in which the brightwork stays in excellent condition. Cockpit shower is another story . . . that's the way to go! No muss, no fuss!
Thoughts on a Pearson 10M DrB Boat Review and Purchase Forum 11 06-07-2011 06:41 PM
Pearson 34 versus O'Day 34 DrB Boat Review and Purchase Forum 1 04-16-2007 02:25 PM
1969 Pearson 32'?? capt.terry28 Boat Review and Purchase Forum 2 10-09-2006 12:00 AM
Pearson 303 jwieneck Boat Review and Purchase Forum 1 05-31-2006 03:45 PM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
