09-21-2007
I'd also vote for the Morgan. Using an outboard on a boat designed for an inboard is going to have some serious effects on the sailing ability and stability of the boat. You've removed a fairly heavy weight from the interior of the boat and now hung it off a make-shift bracket off the stern. The boat is going to squat, and probably hobby horse as well. Also, unless the boat was designed for an outboard, the engine will usually have serious issues in anything but nearly flat seas.
