Marine Stoves, Ovens - SailNet Community
post #1 of 16 Old 03-28-2002 Thread Starter
We have just purchased a Cal 34, 1977,located in Belllingham WA. My wife and I intend to sail her to Seward, Alaska in June of this year, approx. a 3 to 4 week cruise with a 600 mile ocean crossing. This vessel does not have a built in range with oven. Previous owner used a portable propane stove and barbecue in cockpit. We want to install a real range top and oven. These older boats have no propane lockers. Our options seem to be to either install a propane locker in the lazaret with new through hull fitting for venting, or install a new alcohol fueled stove. The alcohol fueled Origo 6000 built in Sweden is the one we are considering. We would really like to use this stove and avoid propane. Anyone with thoughts on this.
rclampitt is offline
post #2 of 16 Old 03-29-2002
Moderator
Jeff_H's Avatar
I have used an Origo stovetop for the past 13 years and really like the Origo. The stove is very reliable, safe and easy to use. Unlike earlier alcohol stoves, I find that things heat up quite quickly on the Origo. The burners are rated at a heat that is very close to a typical marine propane burner. (Land based propane stoves generally have higher heat ratings). The Origo seems to be very fuel efficient. I typically used less than a half gallon over a whole sailing season but the high quality alcohol suggested by Origo is not inexpensive.
I had just been through the same problem that you are going through in that my recently purchased boat''s propane locker was no where near legal, and there was no easy way to make the locker easy. I installed an Origo 6000. I have yet to use the oven.
I had also seriously considered the Wallas diesel fuel fired stove. These are really neat stoves. While pretty expensive the idea of using diesel is extremely appealing since alcohol and propane are not always easy to obtain but diesel is readily available everywhere.
Defender Marine has the Origo 6000 on sale on their website for $899 which is the cheapest price that I have found. http://www.defender.com/cgi-bin/Web_store/web_store.cgi?keywords=Origo&frames=yes&store=yes& Submit1=Search
If you decide to go with propane, I have a almost brand new Hillerange two burner propane stove/oven that I would like to sell. Email me if you are interested.
Good luck,
Jeff_H is online now
post #3 of 16 Old 03-29-2002 Thread Starter
Jeff, thanks for the report on the Origo stove. I think that is the way we will go.
post #4 of 16 Old 03-07-2009
Marine stove
I read your post re: stoves. I am in the market to buy a LPG stove/oven & wondered if you still have yours available for sale & its condition etc.
Regards John lake (SVImpunity)
SVImpunity is offline
post #5 of 16 Old 03-07-2009
patrickrea's Avatar
I would be willing to bet no as the post is 7 years old.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
patrickrea is offline
post #6 of 16 Old 06-29-2009
CNG stove w/Oven
John, let me know if you're still in the market for a stove. I have a good, working Tasco 3 burner stove with oven I'm taking out of my boat for racing.
It's fueled by CNG, but I have all the parts (still installed and working)
r/Mark
ctsailor55 is offline
post #7 of 16 Old 06-29-2009
Moderator
Jeff_H's Avatar
That stove is long gone. I sold it to a friend almost immediately after posting that back in 2002.
post #8 of 16 Old 07-01-2009
Bermudahigh's Avatar
ct sailor
i sent you a PM w/contact info for me.
would like more info. either email or post it here.
dimensions, condition, mfgr, etc.
thanks.
Bermudahigh is offline
post #9 of 16 Old 07-06-2009
Tasco Stove
Thanks John. I can't reply to PMs or send emails here til I have 5 posts. PLease send me email and I can reply to those. I'll get dimensions, etc. ASAP.
I'm in CT so we're no that far away.
post #10 of 16 Old 07-06-2009
Tasco Stove
Also, the stove is all stainless steel, it looks like the oven hasn't been used before. Email to: econmar@sbcglobal.net
Regards, Mark
MARINE COOK STOVES DUNCANBABY General Discussion (sailing related) 4 12-09-2012 03:07 PM
Diesel Stoves santeana Provisioning 6 02-26-2012 05:14 PM
Diesel Stoves santeana Living Aboard 5 12-01-2004 02:57 AM
Noaa Marine Weather Images Ocean-Pro Cruising & Liveaboard Forum 1 01-04-2002 06:14 AM
marine stoves HeidiMills Gear & Maintenance 0 07-13-2001 07:11 PM
