Old 10-22-2007
sab30's Avatar
sab30 is on a distinguished road
Minimum Tankage
Just a quick question as I am in the final decision between a couple boats and one issue is tankage. Being that I have never cruised I thought the opinion of experience would help. As a liveaboard doing mostly 80-85% coastal cruising (50% of time at anchor) and 15-20% blue water for passages what would you say is the recommended minimal tankage for fuel and water?
Old 10-22-2007
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
Wow. The answer to those questions varies widely depending on your usage (obviously). Do you plan to use a rain-catch or watermaker on your passages to supplement the tankage? Do you plan to shower daily on your passages?
What boats are you considering? The size of the boat, sailing characteristics of your boat, and the length of your intended passages will play a big role in your minimum fuel tankage.
Sorry I don't have a better answer, but hopefully the above has helped.
Old 10-22-2007
camaraderie's Avatar
moderate?
I would just offhand look for tankage that would allow motoring for 300 miles (gallons would depend on engine size/displacement = mpg's) and about 50 gallons of water per anticipated crew DIVIDED into at least 2 tanks in case one gets corrupted.
Obviously...you can get by with less or add a watermaker but I would consider less tankage "roughing it".
Old 10-22-2007
Valiente's Avatar
You can also carry fuel and water on deck lashed to the mast, but on a 30 footer, that idea gets negative fairly quickly.
You might be interested in some of the Pardey's ideas on tankage and stowage on smaller boats. Not universally applicable, but thought-provoking, nonetheless.
Old 10-22-2007
gnsail is on a distinguished road
This post reminded me of The Voyage of the Frog by Gary Paulsen. Odd flashback of 5th grade. From reading that book, the more tankage the better. (Sorry for the distraction.)
Old 10-22-2007
Melrna's Avatar
Crazy Woman Boat Driver
Melrna will become famous soon enough
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Coastal cruising generally means never being away from a port with services for more than a few days. So fuel tankage will vary with the engine consumption but as camaraderie mention 300 miles is a good start. I am not a fan of lashing fuel or water Jerry cans to anything on the deck. They are safety hazard to both crew and boat in my humble opinion. Water to be carried is one gallon per person per day and that doesn't include any water for showers. Most people say 1/2 to 3/4 a gal per person but that is just for drinking and no other uses like cooking, cleaning and person hygiene. If you are the hook 50% of the time you still should be able to get to services to top off tanks and dump the waste tank.
Old 10-22-2007
moderate?
Mel...I was more thinking of the 15% blue water cruising planned as this is really the only mode in which it is really important. In any other mode...low tankage is simply a pain! (g)
Old 10-23-2007
Melrna's Avatar
I saw that too about offshore cruising. But the flip side to all the fuel and water tanks is most day sailors and coastal cruiser don't use that much fuel and water in the first place through the season. If the same fuel & water is in the tank season after season nasty things start to happen inside the tanks. Instead of sailing, one has to more boat work ( it isn't enough we have more than we can handle now) like fuel polishing, algae control, tank cleaning etc..... So plan according
Old 10-23-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I have 66 gals of water (including WH), but I carry gallon jugs of distilled water for human consumption. I try to stock up (at least 12 jugs on hand) whenever I'm in a place I can get transportation. I also carry individual bottles of drinking water as well.
I have a 28 gal fuel tank, and also carry two five gallon jerry cans, plus two 2 1/2 gal cans for the generator and dinghy motor. To this point, I haven't run out of fuel, the longest run being Destin to Tampa, which was three full days offshore.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 11-05-2007
LyleRussell is on a distinguished road
Send a message via MSN to LyleRussell
In the Army we were allowed 2 quarts per man per day. Backpacking we seem to use (drink & cook & brush teeth) 1 gal per man per day. Showers figure 6 gals per man per day.
The only place this really matters is your offshore legs. Tankage determines the duration of voyage between ports.
Avoid lashing jugs on deck.
Tankage upgrade? rockDAWG General Discussion (sailing related) 9 10-01-2006 11:55 AM
Minimum winch sizing? GC20Squid Gear & Maintenance 2 04-09-2006 07:21 PM
Minimum sailboat size to get two seperate sleeping quarters? duffer1960 General Discussion (sailing related) 9 08-02-2001 12:14 PM
Fuel/Water tankage onewolf Gear & Maintenance 4 07-24-2001 07:10 PM
Minimum sailboat size to get two seperate sleeping quarters? duffer1960 Boat Review and Purchase Forum 8 03-26-2001 06:44 PM
