11-05-2007
Moderator
To my previous comments (quoted below, made in the "Offshore Cruiser" thread), I would add that the relative success of these two models could be a consideration. I don't know how many Valiant 37s were built, but PSC built something in the neighborhood of 300 Crealock 37s. You can usually find around 20 or so on the used market at any given time. By contrast, there are only a few Valiant 37/39s listed in Yachtworld.com right now. So I think you will have a grater selection, from the standpoint of age/price/condition, with the PSC Crealock 37.
Originally Posted by JohnRPollard
My preference would go to the Crealock 37, having now owned two Pacific Seacraft models. The build quality is very high. They are similar boats but there are obvious differences: You will appreciate the security of the raised bulwarks; and the wide, clear side-decks free of shroud penetrations; and the prop protected in an aperture within the skeg; and the at-the-ready anchor system; and the additional engine access through the removable cockpit floor; etc.
The bilge-mounted aluminum fuel tanks can suffer if in frequent contact with bilge water. However, replacing a PSC fuel tank is usually a relatively simple matter. In most instances, they designed and installed the tanks so they can be easily removed and swapped in the event replacement becomes necessary. It is not anything that should cause you concern. If you have to do it, pull the tank and bring it to a welding shop and have them replicate it. If you need suggestions for where to have this done, join Sailnet's PSC e-mail list-serve and there are owners there who can provide guidance.
Good luck to you.
