Old 11-16-2007
sevseasail's Avatar
sevseasail is on a distinguished road
how bad is it?
Hi everyone!
I'm in the market for a trailarable and I found a 1990 catalina capri 16 that seems in good condition other than the fact that has big cracks in the keel.
I have taken a couple of pics to show you guys in hope that someone can tell me how bad is it and if it could be repaired and at what cost.
The boat comes on a trailer of the same vintage which seems in good shape also.
The sails are good and it comes with an outboard that I do not know much about.
The asking price is $1800.
What do you guys think of this cracks? ( I hope the pics are clear; if not I can explain further)
I olmost forgot. The cracks are visible on both sides of the keel and it is a wing keel model. I read somewhere that that the keel in this particular model is made of lead(??) not 100% sure though
Thank you !!!
Old 11-16-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
NADA low retail $2590 with no motor or trailer. It looks like the glass is delaminating from the lead interior (or whatever). Could be expensive to have repaired by someone else. Not that bad if you do it. Several f/glass experts over on this forum...http://www.boatdesign.net/forums/sea...archid=1105820
Old 11-16-2007
SENIOR CHIEF
PS: You DO know (I hope) that even though it's on a trailer, with a keel that big, I doubt seriously you will be able to launch or retrieve it at any boat ramp.
Old 11-16-2007
Personally, I'd pass on this boat. First, it probably needs some serious repairing... second it really isn't a good boat if you need a trailerable boat, since as USCGRet pointed out, in most locations you're going to need a travellift or crane to launch it.
Old 11-16-2007
Tartan34C will become famous soon enough
It’s just the faring and not structural. An easy repair requiring very little skill unless you want a racing finish. Any other problems with the glass? Anything on the hull itself would be a concern but not something in this area.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Old 11-16-2007
sevseasail's Avatar
Thanks USCGRET !
So you don't think this could be some sort damage caused by a bad grounding?
My concern is structural damage. There are no cracks or signs of stress where the keel meets the hull but I've never seen this before.
I didn't look where the keel is attached (inside) to see if anything happened to the bolts.
I'm not affraid of some glass work repair; I've done it before. I just don't want to get more than I can handle.
Will all the glass need to come off all the way to the lead or would you fix it just as you would a cosmetic repair?
As for the asking price: Im in inland Georgia where we have a bad draught problem so I figured it will be a good time to buy a boat.
Old 11-16-2007
sevseasail's Avatar
Thanks..... I was not aware of that. I was in the market for a com pac 16 and on my way to a wedding the other day I saw that on the side of the road and I thought I'll research it.
That put's it out of the list.
Thank you all guys you just save me from making a big mistake.
Old 11-16-2007
My concern is that the crack extends along the join to the wing part of the keel.
Old 11-16-2007
sevseasail's Avatar
It does. It was kind of hard to put the camera in a position where I could capture that due to the trailer but the crack does run along the joint with the wing.
Old 11-16-2007
7Psych is on a distinguished road
THAT would concern me..........
A formula for seaworthiness? Tartan34C Seamanship 29 09-29-2007 06:23 AM
Great day, Bad Day Mick Young General Discussion (sailing related) 8 12-05-2006 01:24 AM
Bad alternator??? cgha33 Gear & Maintenance 11 10-12-2006 04:56 AM
Recovering from Bad Starts Dean Brenner Racing Articles 0 05-29-2002 08:00 PM
Good Lanes and Bad Lanes Brad Read Racing Articles 0 04-25-2001 08:00 PM
