Ferro-cement. yay or Nay? - Page 3 - SailNet Community
post #21 of 52 Old 12-07-2007
1977 Morgan OI 30
Joesaila's Avatar
Insurance
I would find out about insuring it. Most yards won't let you keep it on a mooring field without coverage. If you can get insurance, low ball, offer 2-3 thousand [since it can't be surveyed?] and you 'might' be getting a good deal.
I fear 'down the road headache' though. The old 'you get what you pay for' saying carries a lot of weight...
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #22 of 52 Old 12-07-2007
No survey, No way!
I once watched an bargain ferro-cement boat break in half. The new owner had just taken delivery of the boat and was having it hauled to take care of a few minor issues. The boat came up in the slings a crack was heard, the boat folded fore and aft and that was the end of the bargain.
bubb2 is offline
post #23 of 52 Old 12-07-2007
Sailing Junkie
ehmanta's Avatar
If they didn't use the proper reinforcement mesh or they didn't properly protect this reinforcement from corrosion, then the ferro-cement will have major structural issues which could be catastrophic and deadly. The hull could be brittle and any flex or impact could crack it open like an eggshell.....not to be negative or anything like that
ehmanta is offline
post #24 of 52 Old 12-07-2007
Sailing Junkie
ehmanta's Avatar
And...... the only way to find these things out is to get a survey and look for the tell-tale rust weeping thru cracks in the cement, but then again, all that tile on the inside will be covering that up and the new topside paint on the outside will mask any exterior signs.....stay away from this one!!!!
ehmanta is offline
post #25 of 52 Old 12-07-2007
I never have been able to "get" the logic.
Would you spend 9k on a car they wouldn't let you test drive?
Would you spend 9k on a car that they wouldn't let your mechanic raise the hood?
And to think, I just sold that beachfront condo in nebraska. I wouldn't give people the address, or let them look at the property.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #26 of 52 Old 12-07-2007
Originally Posted by BlowinSouth View Post
Yes the 'no sea trial, no survey' thing was a huge red flag to me too but when you offer a 32' bluewater boat for 9k I kind of understand why they say that. To keep the tire kickers off the dock.
Anyone who is so interested in a boat that he is willing to pay several hundred dollars to have it professionally surveyed is not a "tire kicker." He's a likely buyer. When the seller prohibits surveys, he's not eliminating tire kickers...he's eliminating potential buyers. Why would he do that? The only apparent reason is that, as others have said, he knows something about the boat that he hopes you won't find out until after you buy it.
The fact that the listing says "no surveys" doesn't necessarily mean that you can't have it surveyed before you buy it. That's open to negotiation. If you look at it, you can make an offer that is contingent on the results of a survey by your surveyor. If they still refuse, then there's no way I'd buy the boat. No honest seller in his right mind would reject a contract from a ready, willing and able buyer on a ferrocement boat, just because the buyer insists on a survey.
Sailormon6 is online now
post #27 of 52 Old 12-07-2007
Moderator
Jeff_H's Avatar
First of all, the Tahiti Ketches were dismal boats in their original design. While they represented cheap way to go cruising using 1920's design concepts, They were anything but good offshore cruisers by any objective standard. Then with the added hull weight and reduced ballast of a ferro version it can only make them worse.
As for Fewrrocement you might want to look at the rather long and very detailed discussion on ferrocement boats over at the Cruisers Forum.com. http://www.cruisersforum.com/forums/showthread.php?t=397&highlight=Ferrocement
Its a good thread with people weighing in on both sides, including a number of people who actually own ferrocement boats. My opening comments were as follows:
My take on ferro-cement is that it is, in fact, pound for pound the weakest of all of the commonly used boat building materials. Ferro-cement operates by the same principle as fiberglass, in other words, a high tensile strength reinforcing held by a high compressive strength, low tensile strength cement. The cement in ferro-cement ideally is a high strength Portland cement with a very fine sand aggregate. The cement in fiberglass is polyester, vinylester or epoxy resin. The tensile reinforcing material in ferrocement is steel (sometimes with glass fiber added), and in fiberglass it is glass fibers in a variety of forms, kevlar, carbon and all kinds of new variations on these materials.
Ferro-cement's weight comes from a number of sources. First of all, no matter how small the boat, there is a practical limit to how thin ferro-cement can be. Ferro-cement needs to have a minimum thickness in order to have sufficient depth of material to protect the reinforcement from moisture. Because of this boats below 40 to 45 feet are generally considered too small to use ferro-cement efficiently. (i.e. their hulls, and deck structures weigh more than they would in some other material.)
The implication of the weight issue is not readily obvious. At the risk of sounding like a broken record, Weight in and of itself does nothing good for a boat. It does not make it stronger, or more comfortable or more stabile. Weight does increase the stress on the various parts of a boat. It increases the size of a sail plan required to achieve a particular speed. It increases drag and typically means that for a given draft a boat will have a less efficient keel (i.e trading off greater drag for the same amount of leeway.)
In order to carry more sail area the heavier boat with equal or less ballast stability needs greater form stability, which comes at the price or a choppier motion and greater drag, or greater ballast or deeper ballast which adds more weight and drag and perhaps depth.
To keep the weight down, many ferro-cement cement boats have reduced ballast ratios when compared to other construction techniques. This means that they need more sail area because of their weight but they can't carry more sail area because of reduced ballast ratios, at least not without using lower aspect rigs which are by their very nature much less efficient on almost all points of sail.
This is further complicated by the fact a higher proportion of the weight in a ferro-cement boat is carried in the in the topsides (and sometimes decks). This means a high center of gravity which has a variety of implications; reduced stability, wider roll angles, smaller angles of ultimate stability, and more prone to excitation rolling (which may be slightly offset by the greater inertial moments due to weight).
This added hull and deck weight, larger sail plan, and perhaps greater ballast requirement to carry the sail plan make these boats a less than ideal choice for distance voyaging for a variety of reasons. Any given design can only safely carry so much weight before it begins losing safety, stability and sailing ability. If excess weight weight is required for the hull, deck, rig and ballasting, there is less weight available to carry food, stores and gear. For a given payload, a bigger more capacious boat is required. And since displacement is a major component in determinging the amount of anticipated maintenance costs (affecting sails and deck hardware size, ground tackle and dock lines, engine size and fuel consumption, down to even simple things like the amount of bottom paint required), these boats that are become expensive to maintain as well.
Then there is maintenance costs. In a study performed some years back looking at the life costs of various materials, ferro-cement-cement came out as the highest maintenance cost material (if I remember worst to best was ferro-cement, steel, conventional wood, aluminum, fiberglass, cold molded wood) Of course as with any generalized study there will be case by case exceptions and given the comparatively small sampling of non-FRP boats the results could easily been skewed by a few bad apples.
Other problems with ferro-cement are the difficulty of connecting things to it, and prevention of rot in wood in contact with ferro-cement. The difficulty in bolting to ferro-cement is that ferro-cement hates localized loadings. It’s hard to glue things to ferro-cement. secondary bonds are greatly greatly weaker than primary bonds.
Then there is the market value thing. ferro-cement does have a reputation in the States that does not match the comparatively high regard that it is held in other countries. Some of this is just plain unfair prejudice but some of this comes from real shortcomings in the materials as noted above. A well-built ferro-cement boat can be a reasonably good cruising boat. But the image of the crudely finished ‘hippie’ built cement and rust buckets still clouds the perception of ferro-cement for many North Americans.
The other problem is telling whether the boat that you are looking at is a good boat. It is very hard with non- destructive survey techniques to tell whether the original work was done well and is in good condition. While sounding will reveal any major separations in the cement to reinforcing bond, it does little to determine the affects of fatigue, poor curing practices or cold joints. With Ferro-cement it is particularly important to maintain the ferro-cement parts in good condtion. That can be very significant. People who buy boats because they are priced well below the market, often are overly frugal or just plain do not have the money that it takes to properly maintain a boat. An otherwise good Ferro-cement boat left to poor maintenance and miss-handling can quickly become a poster child for why North American’s don’t trust Ferro-cement
To me the real cost of owning a boat is the difference between what you paid for the boat, the cost of upgrades and maintenance and the price that you can get when you sell the boat. The problem with a lot of low value boats is that the sales price is always limited no matter how much you put into the boat. This too works against ferro cement boats.
I guess my conclusion is if you are strictly looking for an initial up front cost boat and don't mind putting some sweat equity in, and you can look past the sailing shortcomings, and you actually find one that was well built and well maintained, a ferro-cement boat might work out fine for you. For most of us, they do not.
Respectfully
Jeff_H is offline
post #28 of 52 Old 12-07-2007
Freesail99's Avatar
Very informative post, thanks Jeff.
S/V Scheherazade
Freesail99 is offline
post #29 of 52 Old 12-07-2007
In fewer words...NO
ehehehehehehehe
And I am right...less weight is better..Go Giu!!!!!Go!!!!
Giulietta is offline
post #30 of 52 Old 12-07-2007
Best Looking MALE Mod
Cruisingdad's Avatar
Bottom line:
You have concerns now, before you buy it. When you are out in a blow, you need a boat you feel good about. When you are at the marina, you need a boat you are comfortable in. When you are West Marine, you need a boat you know isn't a giant hole in the water (that you might actually get SOME of your money back on).
So, is this that boat? You have to answer that. The little nags right now turn into big nags after you are many thousands into the tub. They turn into HUGE nags when you are in a gale/storm. THe are ENORMOUS nags when you list it again with a broker.
What is your sailing experience? I have to ask why get this type of boat anyways. What is wrong with an old Catalina 30? They were well made for their time and still coveted by MANY owners. At least you could get your money back and have a nice support group of other owners. The C30 is not the only boat I would reccomend... it is jus the first to come to mind.
Take care. Whatever choice you make, it will be the right choice.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
ferro cement boat annemminix Boat Review and Purchase Forum 8 12-02-2011 12:25 PM
Ferro cement dshearn Boat Review and Purchase Forum 15 02-28-2008 09:02 PM
Buying a Ferro Cement Boat rainydays137 Boat Review and Purchase Forum 10 08-22-2007 11:54 AM
ferro cement boat annemminix Cruising & Liveaboard Forum 3 09-16-2003 12:27 AM
need help on ferro cement boat. pierot69 Boat Review and Purchase Forum 0 01-27-2001 11:48 AM
