finding the perfect dingy - Page 2 - SailNet Community
post #11 of 20 Old 12-25-2007
Helms ALee!
tenuki's Avatar
Harpoon 5.2, although hitting the heavy side of things, still under 500lbs
member
tenuki is offline
post #12 of 20 Old 12-25-2007
The Jersey Skiff I mentioned is only 360 lbs... with a trailer it's probably not much more than your motorcycle and trailer... it's design is based on old rescue skiffs, so it is pretty seaworthy, especially if you get the decked in version.
sailingdog is offline
post #13 of 20 Old 12-25-2007
Sailingdog...You have a PM.........
7Psych is offline
post #14 of 20 Old 12-25-2007 Thread Starter
The jersey skiff is beautiful, although I must admit to some trepidation in my head about taking something that looks much different than an oversized wind surfer out there for fear of swamping her, whereas if there's no cavity in the boat, there's nothing to swamp. I suppose I should get over that fear and actually try to get a ride in some of these things.
-- James
jbarros is offline
post #15 of 20 Old 12-25-2007
James-
That's why I recommended the decked version of the boat, which has a closed off fore deck. Most small boats of this size are unballasted and have full flotation.
-- James
post #16 of 20 Old 12-25-2007
Helms ALee!
tenuki's Avatar
Wayfarers have been sailed from Scotland to Iceland and across the North sea several times. Plus, you can pick one up used for the price range you are looking for. They also have a spinnaker and an active west coast racing class.
member
tenuki is offline
post #17 of 20 Old 12-26-2007
After looking at the Wayfarer, I'd say that it might be a good choice. It's about the same weight as the Jersey Skiff and probably avaiable used in your budget range.
post #18 of 20 Old 12-26-2007
Moderator
Jeff_H's Avatar
Welcome back James. I kind of missed your frequently thought-provoking questions.
I would suggest that you look for a self-rescuing design, by which I mean a boat with adequate floatation tanks near the rail that it will float high out of the water and can be righted and will drain if swamped. A properly configured Wayfarer isn't a bad choice. Some other options that come to mind might include the Jet 14, Flying Jr., Pearson Lark 14, the Explorer 14, and perhaps the Oday Daysailer (a little outside your weight range).
Jeff_H is offline
post #19 of 20 Old 12-26-2007
"Hello, My name is James and I was on this forum LONG ago"
This sounds like a personal introduction at a "Sailnet Anonymous" meeting.
Welcome back, I too remember your contributions. I also agree with Tenuki's suggestion that you take a look at the Wayfarer. They are pretty common on the Canadian side of the Great Lakes since Abbot makes them and have an excellent reputation for stability and safety (for a daysailor) with decent performance.
Here is the long distance voyage that Tenuki referred to:
http://www.amazon.com/Ocean-Crossing.../dp/0713675683
Johnrb is offline
post #20 of 20 Old 12-26-2007 Thread Starter
I'm flattered
Wow,
I honestly didn't think I'd be remembered, but I'm flattered.
I'm digging through information on the wayfarer association website now, as well as a few of the other boats mentioned.
Thanks.
-- James
jbarros is offline
Cruising with a Hard Dingy on Davits LWinters Cruising & Liveaboard Forum 6 12-27-2006 08:32 PM
Dingy Questions PalmettoSailor Gear & Maintenance 10 07-26-2006 10:02 AM
